Question about Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV
Lost some stations on my Sony lcd TV.
I have basic cable.
My TV is a 5yr. old Sony KDF-50WE655 grand wega LCD projection.
It has worked fine up until a couple of days ago when I seem to have lost the HD channels.
I also have a 4 mo. old 19" View Sonic that still gets all the channels the Sony used to.
Is this a signal problem or a TV?
  • ezak61 Jul 04, 2009
    Thanks! I tried to reprogram it and it only found the same channels.
    Like you said the cable company wants me to rent a box.
    I then re-routed the coax straight to the TV instead of through a spike protector.
    I then ran the auto program again and it came up with a lot more channels.
It is a possibility if you are using a cable tv service, without a converter box, that the cable company has limited the number of station you are able to receive. It seems to be their new ploy to get subscribers to get a box since the digital changeover. I also may be that the TV's tuner memory may have to be re-programmed. Go into the menu and go through the channel scan process and see if they return. If they don'y it may be a tuner issue. An easy fix is to get a cable box!
Hope this has been helpful
Posted on Jul 03, 2009
Sony Projection Wega TV
It was better to replace the light engine as a unit to such an old PTV.
Electro help
Jul 27, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
My LCD projection HD TV model KDF-50WE655 has an
Is your TV LCD or DLP? Encompass Parts shows your model to have Lamp with part number for lamp as A-1606-034-B which then means DLP ,which then it means you may have your light engine going bad which is called optics unit Block part number is
A-1084-660-A They do have them in stock Call 1-800-638-3328 or visit their website www.Encompass Parts.
Nov 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony Grand Wega LCD TV currently has a large blue spot on the left side of the screen when powered on. I have changed the lamp, but this did not solve the problem. Could this be caused by bad component...
I'm afraid, it is problem of optics unit block (light engine), there are 3 LCDs red-green-blue for color picture formation and blue LCD sounds bad, please call local TV tech for fix.
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
It is most likely a signal issue. Bad coax connections, splitters and faulty cable are usually the culprit. Best to call your cable company and request a signal test. You may also try swapping tvs. Swap sony with viewsonic in the room where viewsonic tv is.
Jul 03, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Dark picture after purchasing a new lamp. didn;t help at all
CHECK FOR COLOR CONVERSION OPTION IN THE MENU,,TRY THAT ,,ALSO TRY NEW CONNECTIONS ,,AND RCA JACKS AND SO ON
May 05, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
6 red blinks wont turn on sony rear lcd projection
thermal fuse. it sits below the lamp and has popped. replace with new fuse or just short (eliminating fire protection) let me know if you need instructions.
Dec 09, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Bad picture
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
http://splinke.googlepages.com/sonyrearprojectionlcdtv-opticalblock
Jan 19, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony wega KDF-42WE6 55
Jan 16, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Sony Grand WEGA KDF-50WE655 50" Rear Projection HDTV Logo
143 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
