Loaded staple gun will not work. Is it locked?
SOURCE: I loaded the stapler as described above. Now I
You need to load just enough staples in it that when you put retaining spring and clip back in that it will let catch on back of spring to go into slot in frame. I hope this helps. Thank you
SOURCE: how to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
SOURCE: just got an ET50red electric
remove the staples and check inside for a jammed one up there. squirt some oil in there. load it again and try. please follow the instructions to a tee. having the wrong staples or what ever can damage the unit, if it isn't already. good luck
