Question about Sony Handycam DCR-DVD405 Camcorder
Disc Error C: 13:02 on Sony DCR-DVD405
Disc Access error after droping the camera. The disc spins but the Access light doesn't flash as before.
Drawsalot
  • 38 Answers
SOURCE: error code sony dcr trv25 c:31:23
Sony says the unit needs a power reset (error 31). Unplug the camera, remove the battery and wait several minutes before re-attaching the battery and/or AC cable. Then power the camera back up. The 23 code says you need to use a InfoLithium battery-- apparently these are smart batteries that give data back to the camera. These error codes seem to be quite common however, and so a hardware issue may be the case. Some users have said that removing the battery while the camera is powered on will clear the codes. Others advocate "smacking" the camera, I would not however, recommend this. www.sony.com is a good place to look for more information.
Posted on Nov 21, 2007
SOURCE: Sony DCR-DVD 108 disc won't play or record
u tooo have same problem .. i recorded my whole trip on Dvd RW now the camcorder or computer shows fileformat as RAW rather than VR.. plz suggest some solutions.. all i want is my recordings back
Posted on Jan 08, 2008
ctf1800
  • 4402 Answers
SOURCE: Sony Handycam Error 13:02
go here
Posted on Jun 11, 2008
welcomejee
  • 10594 Answers
SOURCE: DISC ERROR
Clean optical lens (where you put disc) of your camera with soft cotton swab. Hope problem will be solved.
Posted on Jun 22, 2008
welcomejee
  • 10594 Answers
SOURCE: Disc Access error
Clean the optical lens in camera with nice quality soft cotton swab.
Posted on Jun 25, 2008
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
How do you delete videos from your sony handycam DCR-DVD405
This Sony camcorder uses mini-DVDs to record and there are certain restrictions when DVD is used, it is not like videotape. For a DVD-R disc, you cannot delete video once it is recorded because this type of disc is a record once only. Depending on which other disc type you use and how it was initialized, you MAY be able to delete video. For a DVD+RW disc, or a DVD-RW disc initialized in VIDEO mode, you can delete the last scene IF you have not removed the disc and not recorded any new video. For a DVD-RW disc initialized in VR mode, you can delete anytime. And here is how:
Turn on camcorder and press PLAY. Select the video or still image tab that contains the data you want to delete. Touch EDIT. Touch DELETE. Select what you want deleted. The selected scene is marked with a checkmark. Press and hold the image on the LCD screen to confirm. Touch RETURN to go back to previous screen. Touch OK - YES. You cannot recover data once deleted. There is also a DELETE ALL to delete all video or images.
Mar 22, 2011 | Sony Handycam DCR-DVD405 Camcorder
Every time I turn my sony on, it reads disc error,
your disc inserted is the problem change another one.
Jan 21, 2010 | Sony Handycam DCR-DVD101 DVD Camcorder
Disc error! remove disc
actually ur lens got weak and it is unable to prepare the disc for writing if u can see ur lens u can try cleaning it with soft cloth very soft or u can buy a dvd cleaning kit for ur camera it will help other wise u have to change ur lens
pls rate me if it helps
Dec 16, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
Disc Access error
Jun 25, 2008 | Sony Handycam DCR-DVD100 DVD Camcorder
DISC ERROR
Jun 22, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
Disc Error: Remove Disc
YOU PLZ CONTACT WITH NEAREST SERVICE CENTER.
Nov 07, 2007 | Sony Handycam DCR-DVD103 DVD Camcorder
Disc access error
check for smudges on the disc or on the laser optic sensor. cleaning liquids and cleaning Disc kits may be found in Camera and PC stores. if you need extensive services we can provide the service manualat a reasonable cost.
Dec 04, 2006 | Sony Handycam DCR-DVD92 DVD Camcorder
Sony Handycam DCR-DVD405 Camcorder Logo
260 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
