Question about Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump
Proline 1.5 hp pump gets hot and trips breaker.
Just opened our pool which was new last year. The filter was in storage in my garage for the winter and was completely emptied and cleaned at the end of the last season. After setting it up it ran for about 8 hrs the first day. After starting to vacuum the second day I kept losing suction so I back washed a couple times then decided to just completely take apart, clean then recharge the D.E filter again. When I turned off the pump I noticed it was hot. After setting it all back up again I turned on the pump it was noisy for two seconds then tripped the breaker. I tried three more times with the same results. The pump was hot to the touch. Any suggestions??
  • 22 Answers
Motor is locked up in the motor are two bearings they will rust if they are set up for a while.you can take the back off the motor and where the shaft goes thru the houseing take a pair of needle nose plires and try to free it up.
Posted on Jul 10, 2009
GFCI Breaker tripping when turned on
Try running the motor in the dark. You may find it arcs to the chassis of the motor and that is your culprit. Had same thing on a hot tub 10 years ago. The professional techs tried everything for me. i finished the last part at 10pm and turned the motor on and saw the arc then trip the gfci. Good luck
Jun 13, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
Vs pump trips breaker. single stage 1 1/2 pump works fine, does not trip
is motor getting hot if so need new motor also check to see if wires on the back of the motor are loose or the wires to the breaker loose if they are ok you need a new pump motor or pump sometimes a whole pump is cheaper than fixing the old one
Jun 01, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
My brand new 1.5 hp, 230/115 v pentair runs for several minutes, gets hot and then shuts off. (not tripping the breaker) ...wiring was already in place on previous 1.5 hp, 230/115 jacuzzi brand pump for...
It is probably only getting 115V from your circuit which will cause it to overheat and trip the overload yet it will not draw high current which would trip the breaker. Can you confirm your line voltage with a meter? If it is suppoed to be a 230V line then look for a bad leg of power, again, checking each leg to ground using a meter.
John
May 28, 2011 | Pentair 15 Hp Superflo Swimming Pool Pump
My pool sweep had been doing fine. Now the new pump seems to be dragging as if it is running on half power and the sweep crawls slowly. The pump gets hot and shuts off. The pool filter pump on the left...
My opinion is that new pump is defective.
You posted under Intermatic pool timer.
The timer will not have any effect on the new pump overheating.
Insufficient wiring can cause new pump to overheat.
However if wiring is undersized, and/or if both pumps are turned ON at same time, the circuit breaker would get hot and trip.
Instead of the breaker tripping, your new pump is getting hot, and turning off.
Remember, any pump that slows down and overheats is getting damaged.
Replace the defective pump.
Feb 28, 2011 | Intermatic T10404R - two 220 time clocks...
Pool pump shutting down -- heater?
Trying to get the TA correct before you kill the alge? Leslies diagnosis?
You probally just need to kill the alge before you do anything. Nevermind the TA for now and just add about ten gallons of liquid chlorine. The alge untill you kill it will plug the filter constantly. This will give you the code on the heater and will make the pump run very hot and will hurt the plumbing by shrinking it. This will stop water flo by letting air in also it will leak water at the pump discharge.
A lot of liquid will break the alge as it is unstable, but use a lot.Once you kill the most of the alge then add probally another four gallons and now brugh the whole thing real good. now you can start running again and start with all the stuff they will sell you to adjust the PH and TA. I hope this helps, and good luck.
Jul 13, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Hello, We have had our Hayward Super Pump 1hp for 6 years with no problems. Just yesterday it started tripping the circuit breaker. It would run between 30seconds to a minute and trip the breaker. Could...
6 years is a good time - you must have house for your pump :)
If you are close to a pool shop - take it in and get it tested - somtimes it will just need a service.
Jul 13, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Filter pump will not work
take a pliers and turn shaft with pump off if it turns, turn pump on they tend to stick from not being used
Jun 08, 2009 | Intex Krystal Clear Model 635 Pool Filter...
My new Hayward Super Pump is over Amping
Sounds like the wire gauge (thickness) is to small
Jun 04, 2009 | Hayward Pool Products Hayward Super Pump
Hayward Sp2607x10 Super 1 Hp Swimming Pool Pump Logo
480 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
