Question about Samsung DVD-P181 DivX DVD Player
I have a region 2 samsung dvd player. All of a sudden the following message displays: '' Can not play disk. Wrong region code'' We have been playing the dvd for more than 1 year. What is the problem? Same legal dvd,what is the problem?
    Brigadier General:
  • 3,006 Answers
What follows is mostly generic advice which applies to the vast majority of DVD players which I've tinkered with.
Your problem normally only happens if someone else has played a different region coded DVD on your machine. Normally you get seven chances to reset the region code before the machine locks itself permanently to one of them. before the changes are permanent the player will usually ask you if you want to change the region code when you try to play a disc from the wrong region.
Before doing anything else it's worth asking other members of your household if they have recently used the player, especially if you know anyone may have been using imported discs. If they've used up all of the region changing opportunities then hacking the machine might not work at all.
If you use a search engine you can search for DVD-P181 hack and these will guide you through the process to make your DVD player a multi-region machine, but there are three different hacks which I've seen for the same player so you may need to try them all.
Posted on Jul 03, 2009
DVD player is saying "Wrong region"
region codes are as follow. Region 1 North America, Region 4 South America, Australia, Region 2 Europe, Region 5 Asia Major,Africa,Region 6 Asia Minor, Probably your DVD is from another region....hope this helps
Jan 01, 2010 | Insignia Televison & Video
Samsung H1080R plays wrong region
Same problem, no support from Samsung Netherlands.
No solution yet, sorry
Nov 12, 2009 | Samsung DVD-H1080R DVD Player
Cannot play this disc
1) Physical fault
use a blower and clean the internal parts by blowing
2) fault in the lense section of the player
may need a thorough cicute scan
Sep 28, 2009 | Samsung DVD-P181 DivX DVD Player
I have bought samsung dvd player h1080 and it seems that it is region 1 how can i make it region 2. thanks
After searching the best known region hack databases I have found one process for your make and model. I can not assure you that it will work 100% but it's the only known process.
Turn on the Player with no disc on the tray. The tv screen and the dvd lcd will display "No Disk"
2. Press the "Repeat" key on the Samsung remote control
3. Press the keys: "5 7 5 3 8" on the remote. Number 2 appears on the screen for a short time.
4. Press "9". Number 9 is displayed on the screen.
5. Press the "Open/close" button in the remote. The tray will open. Leave it open for a few seconds.
6. Just press the "On/off" button in the remote.
7. You now have a multi-region dvd player!!
I hope this works for you, thank you for choosing Fixya!
Aug 29, 2009 | Samsung DVD-H1080 DVD Player
Samsung dvd htx200 region error
no solution but i have exactly the same problem - the system has suddenly stopped playing any dvds at all including ones it has previously played - i get no sound or picture just a circle with a + sign in the middle on the dvd digital display
did you find any solutions elsewhere?
Aug 28, 2009 | Samsung Televison & Video
Can a region 1 DVD be played in australia
DVD-VR330: region free
1.Turn DVD player on without a disc inside
2.Hit 'MENU' on remote control
3.Enter code: 57538
4.The current region code will be displayed in the top-left corner
5.For region free press 9 (region 2 UK, region 1 US etc)
6.Power OFF and power ON
Remember your region code that displayed.Some disks sold in your area will only play if your unit is set to your region.In that case go thur process again and instead of 9 put your region number in.Need more help majortom350@yahoo.com.
Aug 22, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
I moved from the US to Egypt. When I try to play
Hello!
Please refer to the article given below to know about the DVD region code.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C125695
In order to play DVDs of any particular region that is not currently supported by the DVD Drive installed in the Computer, you may change the region code. However, the region code for the DVD Drive installed in the Computer can only be changed maximum for four times. After fourth time, attempting to change the region code will fail and service will be required to change the region code.
You may follow the steps given in the article through the link below to change the region code of the DVD drive installed in the Computer.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C171033
Furthermore, you can reduce the display resolution of the Computer display by going to the display properties.
Jun 27, 2009 | Televison & Video
Unknown disk -samsung HT-x30 DVD Player
FIxed this by downloading the firmware upgrade from samsung and applying it.
Dec 17, 2008 | Samsung Integrated DVD Player and Home...
Region Management display comes on
The following steps should help:
No disk in player
Turn on player
press "pause"
then 3,1,4,1,5,9
"CODE --" will be in view
enter desired region code 0 or 9
press "pause"
turn off unit for 5 - 10 seconds
turn back on
Jun 28, 2008 | Zenith DVC2550 Multi-disc DVD Player
DVD MALFUNCTION
DVDs and CDs are formated with regional encoding 1-6. If your player does not support the format, it will not play the disk. You might try looking up your brand/model player online to see if it has a regional patch code which you can enter via remocon.
Sep 07, 2007 | Pioneer VSX-D608 Receiver
Open Questions:
Samsung DVD-P181 DivX DVD Player Logo
545 people viewed this question
Jerry Greenberg
Jerry Greenberg
