L17LCD2 goes blank
My L17LCD2 displays the proper image when first turned on but after a few seconds the screen goes blank. I can see no image even when shining a light on the screen, so I believe back light is not the problem. Thanks for any insights you can offer.
Jim
  • kd1gd Jul 03, 2009
    I have checked with the previous owner and the monitor has spent its entire "life" on top of his desk with plenty of air circulating and no direct exposure to heat, such as radiators, sunlight, etc. Thank you for the lead though. Based on other listings on this topic, I have removed and tested C922, C924, C925, and C926. None of them seem to be shorted or leaky at 15 volts. ANy more thoughts? Thanks,
    I'm quite sure this monitor is at fault as others work fine with the same PC. As stated in my comment to Solution #1, I have removed and tested all the "popular" capacitors in the low voltage power supply (C922, C924, C925, and C926 and they do not leak or short with 15 volts applied. Any more thoughts on this? Thanks for what's been suggested already. Jim
For you to make sure that this is not a monitor problem, try unplugging the cable at the back and there should be a message " MONITOR SELF TEST" if that didnt show up, you have to replace the monitor and just make sure the connection on the back of your computer is not loose.
Posted on Jul 03, 2009
    Sergeant:
    Champion:
  • 212 Answers
Pls check your chip board heated up or u kept your LCD near by heat radiating objects
Touch screen on acer z290 goes blank after 2 seconds
mine after few second turns off.
cpu remains cod and fan is working and nothing getting hot on matherboard.
Feb 23, 2012 | Acer Veriton Z290G 185 320GB
Benq fp581 screen goes blank after about half a second evertime i turn on my computer.
Even thought the monitor looks blank check to see if you can see a faint image (shining a flashlight at the monitor sometimes helps). If you can see an image it could mean that the inverter board has gone bad.
I have also heard of an overheated computer causing a similar problem.
May 20, 2010 | Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
LiquidVideo L17LCD2 17 in. Flat Panel LCD Monitor - Power Issues
firstly stop turning it off and on because you will blow something else like a power board then it will be a big paper weight.
next get a torch and when it is powered on and supposed to be showing images, shine the torch at the screen.
if you can see everything then you have a broken backlight or problem with your backlight and connections.
they cost approx £15 and a little labour, its not a big job. you may be able to do it yourself if you can get hold of a service manual.
Feb 26, 2009 | Liquid Video L17LCD2 17" Flat Panel LCD...
19" Topsync CRT display is flickering
the motiter to pc cable is problem yaar you change it the problem is solved
Dec 06, 2008 | ZT Group CISNET A7050 PC Desktop
LCD monitor goes blank
It appears that the display resolution set in your display properties is out of the range that the LCD can display.
Try this.
Boot to the ENABLE VGA MODE by pressing F8 to get the Windows Boot Menu. If you can get to the desktop, then go to display properties, and see if you can change the resolution to higher settings and maintain video. (If the video blanks out, then it should revert to the previous setting in 15 seconds)
Aug 03, 2008 | Gateway FPD2275W LCD Monitor
BLANK LCD SCREEN
The shutter in the lens is stuck closed. You need to take the camera to a shop where they will replace the lens assembly.
Nov 25, 2006 | Olympus Camedia D-580 / C-460 Digital...
Computers & Internet Logo
142 people viewed this question
Alun Cox
David Payne
David Payne
