Question about Kenmore Kitchen Ranges
I have a kenmore self cleaning oven and when i turn the oven on it wont heat and just flashes clean
  • bbconst1 Jul 03, 2009
    both elements work on when i clean it
  • 3 Answers
Could be that the heating element is bad, but u should get a kenmore dealer to take a look at it once it is under warranty and try replacing the element
Posted on Jul 03, 2009
Cannot do anything but self=clean
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. More than likely your thermostat or oven control has been damaged and needs to be replaced. I would replace the temperature sensor as well
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 26, 2012 | Kenmore Kitchen Ranges
Kenmore Elite c970-418091 wont work after self clean - Code f30
Here is a how it works post I{ wrote a little while back.:The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. With all that said you can try to cycle the controls by turning the breaker of the oven off for a few minutes the n turn it back on. It should then read PF which is normal. Press the cancel button and try it to see if it works. If not then you will need to replace the control board in the upper panel
Apr 26, 2012 | Kenmore Ovens
Ask a question yesterday did not get an answer .i will ask again kenmore self cleaning oven tried to clean pressed button door locked .after ten minutes oven did not heat up to clean did i miss a step that...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 09, 2010 | Kenmore Ovens
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Nov 15, 2007 | Kitchen Ranges
Cannot get oven unlocked after self cleaning
turn the circuit breaker off for several seconds
this should reset the system
Apr 02, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
94 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
