Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Mower keeps cutting off while trying to mow or ride with blades dis engaged. It will act like it is about to cut off a few times then it finally will. Doesn't matter the throttle position( low or high). The mower only has 12 hours on it and has plenty of gas that is NEW and has the right amount of oil. Some times it might mow for 20 min. before it cuts off and sometimes it might go 1 min.
  • 115 Answers
My brother had the same problem with same mower. he took it to service station new plugs etc. still did it he took his back maybe problem with the magneto/ coil since you only have 12 hours on it, take it back and get a different make ie john deere or cub cadet husqvarna riders are junk!!!!!
Posted on Jul 07, 2009
  • 143 Answers
This might be a stripped wire somewhere, maybe a wire going to a safety switch under the seat or on the cutting deck and it is earthing against the body from time to time.
Stephen.
Posted on Jul 04, 2009
Blades wont engage
Hi Mary:
The drive belt will possibly have slipped off a pulley.
With the engine OFF, look between the cutting deck and the underside of the machine. Check the position of the belt as you have a helper move the engage/dis-engage lever back and forth.
Reply as a COMMENT to this post if you need more assistance.
Cheers
Mar 28, 2016 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I have a White 54" cut 25 hp vtwin Kholer engine. Went start up and needed choke out to keep going like it was starving for gas, but also pto (blades) would not engage. Next evening fine, but did not mow....
If ignition switch is a suspect, next time if the problems acts up, try wiggling and slightly turning the key in the ignition. If you notice any differences, then you have bad electrical contacts in the ignition switch assembly. Hope this helps.
Oct 12, 2013 | Mtd Garden
No spark at sparkplug checked switch when blades are dis-engaged whats next ?
Check to make sure all your safety switches are working properly. Usually these act as a ground to cut off spark to the engine. Any one of them that fails or sticks in the 'closed' (grounded) position will keep the engine from having spark. Otherwise you may have a stator issue.
May 16, 2013 | Swisher 44 Iinch 11.5 Hp Trailmower...
Husqvarna riding mower smokes when cranked and dies when engaging blades
If it dies when engaging the blades it's not getting enough juice to do so. Test the battery and make sure you are getting at least 12 volts. If not, charge it. If so, the solonid is going bad.
Apr 13, 2017 | Husqvarna Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Have an old model riding lawn mower, the mower stated to smoke under the engine. Stop for a while to cool off and started mowing again and cutting belt broke, replaced it. Now the blades want cut, but when...
try removing the belt and try to spin the blades by hand. are they stiff to turn? if yes try to oil the bearing assys up under there and spin em again. if that seems to work out put the belt back on and mow away again! seen this on a neighbors rider a few times
Nov 06, 2017 | John Deere Garden
I am new at mowing lawn with craftsmen 4000 I have finally figured how to lower blade to cut but Is there a lever and where is it to engage blade to work cut???? I think I missing it
You either have a switch for the attatchment clutch switch or a handle on the dash (lever) that you push up to engage the blades. Here is a manual for your model mower. You will need Adobe Reader to view it. I HIGHLY recommend you read most of it to help you understand your machine. How to work the controls and the operation of them is on page 13 and other pages. Here is your manual. Please read:
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0407070.pdf
Jul 22, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Vibrations when the cutting head is lowered . Sounds like one of the blades is hitting the cover. Especially noticeable below a setting of 5. Three cutting blades. There is no noticeable loss of cutting...
Sounds like a bent blade to me. Can you determine where or which side the noise is coming from? For safety, I would replace all the blades. I once ran over my son's baseball while mowing and bent the housing and that caused the blade to hit the side of the deck. I simply bent the housing back with a few hits of a hammer and back to mowing I went.
Jul 04, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Mowing deck makes ticking noise when blades are engaged.
A FEW THINGS TO LOOK AT ARE ,1THE PULLY SHIELDSMAKE SURE THEY AREN'T BENT TO CLOSE TO THE PULLEY'S.2 THE PULLEY BEARING'S MAY BE WORE OUT AND TO BREAK .3LOOK UNDER THE DECK TO MAKE SURE YOU DIDN'T GET SOMETHING TRAPED IN THE CUTTING DECK.HOPE THIS HELPED.
Jun 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
427 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
