Question about Refrigerators
Hotpoint RLA64 getting too cold.
It appears that the thermostat isn't working. Even turned to very lowest setting (1) it still keeps cooling.
The thermostat capillary on a Hotpoint RLA64 (and possibly RLA80) is inserted into a tube. The tube becomes detached from the cooling element and so does not sense that the fridge has reached the desired temperature. It then carries on cooling resulting in ice build-up and freezing of goods.
As you cannot remove the top or back of the fridge, you cannot fix the capillary tube back into position. What you can do however, AFTER ISOLATING THE FRIDGE FROM THE MAINS SUPPLY, is to drill a small hole adjacent to the thermostat capillary tube and another in the roof of the fridge next to the interior light and pass the thermostat capillary INTO the fridge cabinet. Use tape to attach the capillary across the roof of the fridge and down the centre of the rear wall curling the last 50mm or so back up towards the top of the fridge. As long as you have dried the wall of the fridge and stuck the capillary securely in place, your fridge should now work correctly when powered up.
Only tackle this job if you are confident and ALWAYS ISOLATE the mains supply.
Posted on Jul 29, 2009
I have a Norcold n611 fridge gets too cold and freezes even on lowest setting.
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 10, 2012 | Thetford Norcold RV Cooler/Freezer
Even at lowest setting refrigerator side freezes up
Possible failure of the thermostat or the sensor to the thermostat that is not working to control the cooling temperature and hence making the compressor work.
Try and set the thermostat to lowest just a little before it cuts off , if this wont work then the thermostat is faulty. Check the wires of the sensor to the cooling coils.
Mar 13, 2011 | Dometic NDR 1292 Refrigerator
My fridge keeps freezing everything even on the lowest setting - does it need a new thermostat?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 25, 2010 | Hotpoint RLA30 Compact Refrigerator
Refrigerator does not get cold. The freezer works fine, but the fridge only gets slightly cool.
normaly the fridge has its own thermostat to keep the tem right, if this thermostat has stoped working it will do one of two things,,, freez every thing up as it wont turn off the compressor or will just stop working as it wont turn on the compressor,,, try turning up the thermostat first,
Nov 19, 2009 | Hotpoint Refrigerators
I have a hotpoint ice diamond fridge which has begun to freeze its contents, even on lowest setting. I replaced the thermostat 3 years ago and again 18 months ago due to the opposite problem of not cooling...
it is the thermostat . the problem occurs when installing the thermostat the small pipe must not bend more than 45degrees. the point of application on the evaparator plate that makes cold is it tight fitted there
May 13, 2009 | Refrigerators
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Further questions about one of your posted solutions
make sure that the thermostat id correctly wired in
May 29, 2017 | Refrigerators
RLA30 Fridge freezing food on lowest setting
From the symptoms ,I would recommend that you have a new thermostat fitted.
This is the cheapest option., fig's do not go wrong that often
Any comment welcome.
Thanks and a merry xmas.
Nov 09, 2008 | Hotpoint RLA30 Compact Refrigerator
Norcold R.V. Frig / freezer not cooling
hi thanks for your question. i had one with the same problem. and i had to spend $ 500.00 to have it repaired. i think you have the same problem. sorry. the appliance doc
Oct 17, 2008 | Refrigerators
Refrigerators Logo
1,130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
