ABS Module Calibration
failure
the car needs to be
all brakes inspected good
and ABS scan tool scanned.
CAN Communication Bus Fault
can bus failures are not good. (and hard to find)
Read more: https://www.autocodes.com/u1900_lincoln.html
It's called a drive cycle, and yes, there are certain parameters that the ECU stores for calibration. In many states that require yearly vehicle inspections, they will make sure a drive cycle has been completed before passing inspection, just to make sure that someone hasn't cleared the codes to get the check engine light to shut off to pass inspection. A simple trip that includes some highway speeds and start & stop driving is usually sufficient to complete a drive cycle.
You can only check to see if it is calibrated, you cannot change the calibration. To test it you need a kit that contains precise weights and you place them on the scale to see what it says. If it is out of calibration, you would have to send it in to have it re-calibrated. If it is being used in a commercial application then it has to be tested yearly by the government and if it fails, they would tell you where it could be repaired at.
what car , exactly , and year. ?????????????????????? but most SLUZUKIs (and some GEO;s but not toyota based Prizms) 45 is Idle Switch
Circuit , grounded all the time. Part of TPS sensor. (too low) or Maladjusted.
Unless you took the batteries to a service center, I am dubious about your ability to confirm the main battery is holding a charge. The average lifespan of these kinds of batteries range between 3-5 years and is likely at the end of its lifespan. This would explain the diminishing performance over the last year if there were significant power or power circuit issues, they would likely be observed on AC power as well. This model of laptop requires the battery calibration utility be run in order for the laptop use the battery. In fact, the battery can show a full charge and still not function if the utility and battery have not been properly configured.. . . instructions on HOW TO do this below. If this doesn't FixYa then the battery will need to be replaced (links to replacement sources) www.BatteriesOvernight.com/HP-Batteries,----- OR --- www.new-laptop-battery.com/Compaq/?Compaq-Armada-E500-battery.htm. You will still have to run the configuration utility when you receive your new battery. Link to Armada e500 manuals:http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01124216/c01124216.pdf How to run config utility: Standby and hibernation must be disabled for the battery to discharge completely and shut off. To use the Battery Calibration utility, first identify whether the battery requires calibration bylaunching the Power Management applet as described above. On the Battery Calibration tab, allinstalled batteries will be displayed in the primary list box. Next to each battery name will be anindication of whether calibration is required for that battery. If calibration is necessary, the phrase“Needs Calibration” will be displayed. Select the battery to be calibrated, and click the StartCalibration button. During calibration, the utility will display an icon on the Windows System Tray to indicate thatcalibration is in progress. Each phase of calibration (charging or discharging) will also bedisplayed. Calibration is complete when the icon is no longer displayed in the System Tray.Battery calibration requires several hours for completion. If you choose to continue using thecomputer during the calibration process, it must be connected to AC power.The calibration process must be allowed to finish without interruption. Performing any of thefollowing actions will prematurely terminate calibration: Clicking the Stop Calibrating button in the Compaq Power tab. Unplugging AC power from the computer. Unplugging the calibrating battery. (This action may result in data loss if a second battery isnot installed.) Undocking the computer. Pressing the power or standby button. Powering down or suspending the machine by using the Windows menu.IMPORTANT: If the calibration process is interrupted, it cannot be resumed. You mustrestart the computer and start the process again.
CALIBRATING WITHOUT THE UTILITY
To calibrate a battery on computers without the battery calibration utility, complete the following
steps:
1. Remove the second battery, if present, so that only the battery needing calibration remains in
the computer.
2. Dock the computer or connect the computer to AC power.
3. Turn on the computer.
4. Check the current battery capacity level by positioning the cursor over the battery icon in the
system tray.
5. Allow the battery to charge to 100%. You may use the computer, but the recharging process
will require more time.
6. Set the system to “drain” mode on the battery conservation settings by pressing Fn+F7, or
select Start > Settings > Control Panel > Power (or Compaq Power in Windows NT).
7. Undock the computer or disconnect the computer from AC power.
8. Restart the computer in MS-DOS mode by clicking Start > Shut Down > Restart the
Computer in MS-DOS Mode > OK.
9. Allow the computer to discharge until it shuts off.
10. Dock the computer or reconnect AC power.
11. Allow the computer to charge again to 100% as in Step 5.
The Amprobe Digital Megohmmeter, Model# AMB-45 is an insulation tester that checks to see if conductors are leaking current to ground or the shield in a coax, for example. It will not check the output of a modulator, it may actually damage the modulator.
