Question about Xerox Office Equipment & Supplies
My Xerox XC830 copies are dark and have lines but otherwise present the image. How can I make the background white again.? Thanks! Ron
    Scholar:
  • 175 Answers
You probably needs some servicing. Drum, developer and other parts have a life cycle and once it's exceeded you can start having copy quality issues. Unfortunately there is no easy fix.
Posted on Jul 03, 2009
Dark streak on copies
Drum, wiper, or fuse rolls. Pull out toner unit see if you can see those lines.on the drum.
Jan 16, 2014 | Xerox XC830 Copy Machine Refurbished
Why do we have blank copies on Xerox XC830?
is it problem when you try to copy vis adf or its aucord in platen glass also?
Sep 17, 2012 | Xerox Office Equipment & Supplies
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
Xerox XC830, flashing 'P'
I have used this tip numerous times with great success.
Remove the paper tray and take all the paper out of the tray. Now on the metal plate that springs up where the paper goes there are 2 fiber pads that are about an inch square. Spray these 2 pads with glass cleaner until they are wet. Wipe off the metal around the pads and re-install the paper tray with NO paper in the tray. Now tray and make a copy....you will of course get the "P" light. Just hit C to clear it and hit the print button again. Do this at least 4 or 5 times. What you are doing here is cleaning the feed rollers by having them turn against the pads with the cleaner on them. Next take out the tray, blot the pads somewhat dry and add paper to the tray, re-install the tray and try copying again.
Should feed paper now unless you have a mechanical issue.
Good Luck.
Oct 29, 2009 | Office Equipment & Supplies
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Xerox XC830 Copier--Paper jams as it is leaving the copier
Inside the copier on the rear side where the gears are you'll find the gear on the fixing roller is broken. You can call Sharp instead of Xerox because there are usually cheaper. The supplies are not interchangeable, but the parts are.
Good luck
Apr 03, 2009 | Xerox DocuColor 12 Color Copier
Dark background copies and has previous document info also
More than likely the heat roller is bad causing ghost printing.
Apr 01, 2009 | Xerox Office Equipment & Supplies
Copy reprints 1st 3rd of copy on 2nd 3rd of page and so on.
the mylar strip is only to capture what the cleaning blade loses, you will have to clean the blade itself. Some blades will age without use, some will wear with use , and some will get paper fibres trapped under the blade edge.....you know what happens when you get a bug under you windshield wiper?
Nov 26, 2007 | Xerox 8830 Copier
Xerox xc830
try cleaning the optics under the glass.
Jun 20, 2007 | Xerox 8830 Copier
260 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
