Question about Gateway FPD2275W LCD Monitor
The on off button on front doesn?t turn the unit off and on
I have a Gateway monitor 2100.The on off button on front doesn’t turn the unit off and on. I have to unplug the power cord. That worked for a while but now all I get is a bright power on blue light for a second or 2 and then the blue light dims, no picture nothing.
I have taken it apart and found that:
A: With NO ribbons plugged to screen panel and I plug in power, the off/on works ok. I get a bright blue light for about 10-15 seconds, like it's trying to boot up and then the light goes yellow like it's going into sleep mode. I can hear a faint buzzing noise from one of two little black boxes on the main curit board it is marked T302. (Could this be the problem)?
B: With the main ribbon plugged into the panel and power applied. I get symptoms as described (NO BUZZING SOUND).can someone help me? I paid a lot of money for this thing.
  • 4 Answers
Same here, your light went out if you put a VERY bright light on you'll be able to see something on the screen if you plug it up to your computer, if you are getting a new one go dell its worth it becase they last and are durable.
Posted on Jul 26, 2009
Gateway monitor 2100 won't turn screen on, blue lite is on as if monitor is. but screen is not on. can it be fuse or what ? is not v-card
It sounds like the lamp for your monitor is no longer receiving power. While you can attempt to fix this issue yourself I wouldn't recommend doing so as it doesn't mean it will work after you attempt it.
If the monitor is under warranty still then you should contact the manufacturer about a RMA. If the monitor isn't under warranty then you should purchase a new monitor.
Nov 26, 2011 | Gateway Computers & Internet
What are all the plugs and buttons for on my gateway 2100 monitor and can it be used as a tv or just monitor for computors i just need to buy power cord
yes you can attach several inputs to this monitor,
the buttons are for ajusting the screen settings and setting the inputs from that tv
Sprint6@zoominternt.net
Oct 10, 2010 | Gateway FPD2275W LCD Monitor
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
When I turn boot up my gt5220 the monitor briefly flashes and then goes into power saving mode- desktop stays on, fans running and all, until turned off by holding power button down or unplugging it.... my...
first try to connect another power source if it does work that is good then try the other options 1- rams 2- vga card 3- cpu 4- of course there is always the motherboard option....
i had the same problem several times mostly it is the power supply ( the power source ) sometimes gives a weak voltage or amps....
Dec 02, 2009 | Gateway GT5220 PC Desktop
Gateway 310 X will not power on
Hi. this is a failed power supply. the power supply pack will have to be replaced. it located on the rear side of the tower in the upper corner. its where the power cord plugs into. replace the power pack and this will fix the issue at hand.
May 17, 2009 | Gateway 310 X (310XSP) PC Desktop
Gateway 19inch wide screen, lcd monitor stopped working randomly.
It could be a faulty power cord. Try plugging it in and moving the cord around in the areas where it takes the most movement. Do the same with the data cable to see if you get a response there. If your cables are fine, the problem is most likely hardware in the monitor - in that case you're better off replacing the monitor.
May 06, 2009 | Gateway 19" Widescreen Flat Panel TFT LCD...
I need a driver for gateway 17 in. wide screen monitor FPD1775W
You might want to consider a default settings reset. To refresh or reset the monitor back to default settings, unplug the monitor's power cord, and then press the the power button for five (5) seconds to drain any residual power. Plug in and then turn on the monitor. The default settings load.
Additional information about your monitor is available on the Gateway support website.
Nov 19, 2008 | Gateway FPD1775W Monitor
Computer won't turn on.
have u tried to unplug the power cord and open up the case aand unplug the power supply from the motherboard and then pressing the power button then plug the powersupply back into the motherboard and pluging in the computer and see what happens please keep me posted so i can help you more if needed ok best regards mike
Aug 19, 2008 | Gateway GT5220 PC Desktop
Strange delay.
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
579 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
