My used Dell Latitute D600 will not turn on.
I shut it down last night after working on it for a few hours. I had it plugged into the electrical outlet (since I got the alert my battery was low). I tried to turn the computer on this morning and NOTHING. No lights....nothing.....The power cord has a green light that is on...but no other lights visible on the laptop itself...UGh...please help.
> Just remove the battery and a/c adapter and make the unit as standalone, which means the unit should be connected to any external devices like mouse, monitor, Ethernet cable once its done press and hold the Power button for 1 min - here we can take out the static charge, if the static charge is more the unit wil not power on.
If this does not fix the issue,
Try reseating the memory and try > Even if this does not fix the issue you may have to replace system board
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dell Latitude D600 PC Notebook
I have a Dell Latitude D500, The problem however, is that a times, the laptop will not turn on...
(More)
I have a Dell Latitude D500, The problem however, is that a times, the laptop will not turn on (power on), instead it will go into a power-on / power-off cycles. It will stay on for few seconds and then turn itself off. A few times, the screen shows MANUFACTURING MODE **** Press Fn-x to return to sys
