Question about Toshiba 50HDX82 50" Rear Projection Television
Accidentally conected it to 220 volt outlet
Accidentally conected it to 220 volt. I know that some newer TV have like a sfety feature for that. is this the case with this 50HDX82 or is it gone
  • aahamid Jul 03, 2009
    great, thanks
    great, thanks
    Scholar:
  • 150 Answers
Hi, damage should be limited to low voltage power supply, I would definitely have a tech take a look at it, video-tek
Posted on Jul 03, 2009
Is the Hunter portable AC High Effiency Model 31125 to be plugged into a 220 outlet only?
if the plate on the side says 220 volts then it will only work on 220 -250 volts outlet
at a 110 volts outlet it will fail and at anything more than 250 volts it will burn up
Apr 20, 2016 | Hunter Heating & Cooling
110 volts, rated TV was plugged into 220 volts power supply. Now when it was plugged into an 110 volts supply its not getting on? What could be the causes? and please suggest solutions.
It probably fried the power supply in the TV unfortunately. If the electrical surge stopped there then it should just be a matter of swapping out the power supply. Provide a make and model of television and I will see if I can help find one with instructions on how to change it.
Nov 24, 2012 | Office Equipment & Supplies
I plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
Oct 17, 2012 | Microsoft Xbox 360 with Kinect
I plug it in 220V
Do I understand you plugged this device into 220 Volts? Is this a machine designed for 110 Volts? Check the fuse - if it is burned out (as I suspect it will be) replace it. If the machine comes on - check out its operation. If it does not come on - I think that is the end of the road for your machine. To get to the fuse, remove the cover. Find the fuse near where the cord enters the cabinet.
I don't know where you live (please do not say) nor what the prevailing standard house hold voltage is. I don't know where you got the oven and please don't say. I really don't understand how you accidentally plugged a 110 Volt machine into a 220 volt outlet - that would be interesting to hear about.
Thank you for your interest n FixYa.com
Mar 09, 2011 | Microwave Ovens
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
Dryer will not start door is closed
Carefully check your 220 outlet. You can check a 220 buy a volt meter. Make sure your volt meter is set over 220 range and put the red lead into the slot and black lead into the L shape. It could be you are not getting 220 power out of your outlet. We all know on a 220 outlet both legs have 110 on each side. A dryer takes 110 for the motor, and takes 110 for elements.
Dec 03, 2009 | Estate TEDX640JQ Electric Dryer
Dryer want start
I am attaching the photos showing how the dryer cord for either a 3 or 4 prong outlet, since I don't know what type outlet you are using. Hope this helps and best wishes.
Aug 04, 2009 | Dryers
Wii got pluged to a 220 volt outlet
I'm going to go ahead and say it probably fried the Wii. I would maybe try getting a new adapter either way if it's at reasonable cost and see if it works again though.
Jul 19, 2009 | Nintendo Wii Console
Maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Jun 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Wiring a stove
If there is no 220 outlet in the location where you're planning to put the stove then you need to run wiring to the new location. There are two seperate phases of 110 volts coming to your home. The voltage between each of these phases and the neutral wire is 110 volts. When your house was wired only 1 of the 110 volt signals was run to your 110 volt outlets. In order to create a 220 volt outlet you need both of the 110 volt signals run to the outlet.
If you have a straight shot between your breaker box and the location where you need the 220 volt outlet then this is not too big a deal. If you have finished ceilings and walls inbetween then this will be much more difficult.
If you're not comfortable with electrical wiring this would be a good time to call a licensed electrician.
Nov 18, 2007 | Ovens
Toshiba 50HDX82 50" Rear Projection Television Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
