Question about Jensen Car Audio & Video
Jensen nav102 with licence key issue
I have a jensen vm9512 and the nav102 unit. the nav system is asking for an activation code and says that the licence key is invalid how do i fix this?
I had the same problem and a very hard time finding any help on it on the web.
The NAV102 is made by Horizion Navigation (www.horizionnav.com)
(866) 286-2831
support@horizonnav.com
I just emailed their tech support and got an answer very quickly (7mins.) from a Support Tech named Todd Carey. He said the software was out of date and directed me to:
http://www.horizonnav.com/downloads.php?index=36
He also asked me for my Device ID - This ID is given on the screen after an invalid code is entered. Mine started with AVX20090304...
(believe that is the manufacture date? after the letters?) With this Device ID he was able to give me the proper activation code.
I haven't actually tried the new software, but wanted to put this out there for anyone else that was having trouble finding info on the NAV102.
Posted on Mar 24, 2010
I just purchased a car with a Jensen VM9512 and it is asking me for a security caode. Can you help
You need to contact the former owner, or any Jensen dealer or Jensen directly via online. You might check your glovebox for a card w/code on it. Those codes are very specific and might require you pulling radio and getting serial # off it. (sorry didn't have a better answer)
Mar 08, 2011 | Audiovox VM9512 Car DVD Player
How do I get GPS & bluetooth stufff to go with this system ?
You need the Jenson BTM15 (bluetooth module) and the Jensen NAV105 (gps) in order to have navigation and bluetooth connectivity thru this head unit.
http://www.mobile.jensen.com/accessories/?sku=NAV102
http://mobile.jensen.com/bluetoothcarkits/?sku=BTM15
These units sell for around $50 (btm15) and $200 (nav102) on amazon.com
Jan 28, 2011 | Jensen Vm9214 Car Video Player
Can you use nav101 on a jensen phase linear or do you have to use a nav102
nav 101 is applicable to any of the Jensen line of DVD media centers...
Nav 102 is just an updated version.
Oct 06, 2010 | Jensen Car Audio & Video
Jensen VM9512HD wants a passcode.
Jensen VM9512 Factory code is: 012345.
May 17, 2009 | Jensen Car Audio & Video
Jensen vm9512 -- is there a master unlock code
MY UNCLE WORKED FOR JENSEN FOR MANY YEARS AND HE HAS A SOFTWARE THAT CAN CRACK THE CODE OF ANY RADIO OF ANY BRAND USING THE SERIAL NUMBER OF IT, IF U LIKE POST YOUR SERIAL # AND MAYBE HE COULD HELP YOU OUT.
Aug 28, 2008 | Car Audio & Video
Heidy5050@hotmail.com
What code? Do you mean an unlock code? You'd probably have to go through the manufacturer for that. If you mean a code to allow DVD playback while moving, there isn't such a thing. To do that you have to wire it a certain way (which is easy).
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Jul 27, 2008 | Audiovox VM9512 Car DVD Player
Jensen vm9512 unlock code for the code
setup menu click language then on the remote pres 54321 unlock the security code.
Jun 14, 2008 | Audiovox VM9512 Car DVD Player
Sirius Tuner
It should work if Jensen says so. Buy from BesBuy, CircuitCity or someone who will take it back in case it is not compatible. Remember to ask for one that would compatible with Jensen. Goodluck.
Feb 02, 2008 | Audiovox VM9512 Car DVD Player
Car Audio & Video Logo
1,438 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
