I have a tx-nr509 and need replacement fuses ms51 125v 10a. also could offer a reason why after several years of great service they would suddenly blow, at less than 40% power. the led said check speaker wires, but I can find no problems.
Please contact our Parts & Services Dept at the number listed below during normal business hours Monday-Friday 9am-5pm EST ; or via email at [email protected]. They can be contacted at 201-785-2600, option # 4 for Parts & Services as they can further assist you regarding warranty and service issues. You will need to speak with the Parts & Services/ Warranty department for any servicing options or resolutions available for your issue.
Could be a shorted out speaker . if there is more than one speaker disconnect one at a time , to find faulty one .
SOURCE: Onkyo TX-SR304
Onkyo offers access to manuals at their web site. HERE is a link to the receiver line.
Personally, I'd connect the speakers to main left/right. The subwoofer to subwoofer out. The Go VIdeo unit to VCR/Video 1, the cable box to Video 2 and the video output to the Sony TV composite input. No need to connect the TV audio out to the receiver since the audio feed comes from the cable box.
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
SOURCE: 2 month old ONKYO TX-SR706 speaker circuit problem
Make sure none of your speaker wires are touching. I had this problem. I re connected the wires. If a wire is touching the case it'll short out. It has a built in cut out.
I still have a crackling speaker on one channel but it doesn't cut out anymore.
steve
SOURCE: tx-8511 blows fuse when turned on. I used Radio
If the unit keeps blowing the fuse means you have a shored parts on it.
See my tips by clicking http://www.fixya.com/support/r8053361-fuse_keeps_blowing. This is also applicable to your unit. The only thing added to check is the stepdown Transformer for short, also the output IC.
Hope it may help you.
Thanks for using fixya.
JDVillanueva
SOURCE: Onkyo TX-SV444 problem
Hello. If the wires have touched, your amplifier probably has what's known a DC Offset, meaning a damaged amplifier. You will need a qualified audio tech to repair this, as this type of forum is not designed for detailed step by step repair.
Sorry.
Dave
We no longer provide service manuals to customers to prevent unathorized and accidental internal damages to the unit and previous history of fraudulent claims of manufacturial defects. We apologize that we can't provide a solution for this request.
