DVD writer, master drive
I plugged in in and the tray opens and has power but now my cd-rom drive doesnt show up or read cds and the dvd drive doesnt show up but is detected and says new hardware is installed. Im not sure how to get them mworking an the software on my disk to help me cant be read now either
  • Anonymous Nov 29, 2007
    won't read any disc or the drive is not showing in my computer.
  • Anonymous May 14, 2008
    my dvd drive does not shown in my computer. If i put some dvd in a tray it will no longer to play. some dvd driver is not installed, says the windows. what should i do? i have free dvd installer here, but it is not work at all.
  • 51 Answers
If you have both the DVD and CD drives connected to the same ribbon cable you want one set to Master and the other to Slave, or both set to CS (cable select). Good luck.
Posted on Nov 10, 2007
My tsst corp cd-writer/dvd-ROM combo only has cd-r in recording tab how do i add a dvd r
when it said "dvd-ROM" .. that means it can only read DVDs (ROM read only memory) .. it cant write DVD... it can only write CDs ... if you want to write to DVDs then you will need to replace the drive ... what you want is a CD/DVD writer ... around here refurbished ones are not very expensive and work great .. you will have a choice of SATA or PATA .. if you have an older computer then its likely PATA .. PATA drives have a wide flat cable connecting them to the computer .. SATA cables are small like lamp cord ... if you get a new drive as a replacement then put the drive select jumper in the same selection as the old one (master, slave or CS) .. another option is you can just add the new drive if you have room .. that way you will have two drives .. you can copy from one to the other .. in that case, if both drives are on the same cable then one must be jumpered as a master the other as a slave ..
Mar 01, 2010 | Office Equipment & Supplies
My dvd writer was working perfectly but when i format my wondow now it is playing only cds & when i insert a dvd it is not giving any response & my driver is also showing as cd-rom
When you formated you erased the driver you need to use your dvd writer as a dvd writer and player. If your dvd-rom came with a cd use it to reinstall the driver and program it uses. Otherwise you can search for your driver thru the manufacturer website or go to and find it there.
Dec 17, 2009 | LG 16X Internal DVD-ROM, E-IDE / ATAPI/...
This drive reads a dvd but not cds. do you have
may be it's only a DVD ROM drive not a combo,
you will need a combo to read both DVD and CD
if it was reading CDs earlier then the CDs might have scratch in them, try with new CD.
did u make changes to the cables inside, if you did check if the cabels are connected properly to the drive
Dec 06, 2009 | Sony DDU1613 16X DVD-ROM Drive, Black...
Internal samsung cd-rom sn-124 doesnt recognize cd's/wont work
replace it. samsung cd rom even its dvd writer have lots of problems. sometime they dont want to open unless you leave a cd in it. sometime it doesnt read cd. better change it. get a Sony, LG, Pioneer DVD writer.
Aug 20, 2009 | Computers & Internet
CD is not recognised by the CD Drive
your dvd writer lens needs to be cleaned by a lens cleaner...
May 28, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Dvds wont play in dvd rom on travel mate 2480
if the icon of DVD is there but when u try to open it doesnt bring any windows gives u error unable to read the contents then ur DVD drive lens is faulty try cleaning it with a very soft cloth open ur drive tray and u will a crystal eye shiny thing just clean it by rubbing very gently with a tissue paper or very soft cloth which is used to clean lcd's or if u have a lens cleaner cd it will be best , if it doesnt work then i will suggest changing the DVD ROM drive there are plenty of cheap DVD writer drives available on ebay under 60 $ or so try them pls vote if u find me helping
Feb 23, 2009 | Acer TravelMate 2480 Notebook
My lg GSA-H55N dvd writer is not playing Cds but plays Dvds fine
your DVD ROM lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working again but be careful remember that no power should be attached to ROM.
or you can buy a lens cleaner from market and try that.
pls rate my solution
Feb 13, 2009 | LG GSA-H55N DVD-RAM Burner
DVD not getting detected
Hi, i have LG GCC4522B CD-RW/DVD-ROM Combo Drive and my problem is that i could open & play CDs. However when i insert DVD the drive doesn't detect the DVD and it shows no DVD in drive or blank. I checked the region setting which is 1. Is it the problem of region setting if so is there any solution for this. Expecting your valuable solution in this regard.
Aug 30, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Pioneer DVR-109 DVD±RW...
This ahs to with speed of recording of the CD/DVD try reading CD/DVD burnt at a lower speed like 16x.
Most DVD writers has low maximum reading speed as compared to CD-ROMs.
You can try burning a CD on it and then reading it, if reads then it shows that other cd were burnt at faster speed than it can read.
If it read lower speed CDs then you can just add an additional DVD/CD-ROM just to read faster speed disks.
Mar 24, 2008 | Pioneer DVR-109 (44121479) DVD±RW...
Computers & Internet Logo
245 people viewed this question
David Payne
David Payne
