Question about Intertherm Heating & Cooling
Unit not blowing enough cool air hotter it get outside hotter get inside
  • 520 Answers
Most likely problem is the a/c is too small for the space Or low on freon.
Posted on Jul 03, 2009
Is the condenser inside the unit
In a window unit the condenser is in the unit and is at the back of the outside section. With a split system or whole house cooling unit the condenser is always outside. The condenser compresses the cooling gas after it picks up heat from the inside evaporator, and forces the heated gas through a coil with a fan blowing through the coil to drive out the heat. A gas can be compressed, but the amount of heat it contains remains constant. A compressed gas will be hotter than non compressed.
Jul 26, 2015 | Heating & Cooling
Replaced a starter capicator, now it just bloweswarm air
On hot day your unit may not cool enough. Make sure that outside unit is clean, filter inside should be clean. If all above is good your unit may be low on Freon.
Aug 11, 2014 | Dometic Heating & Cooling
I have a Honeywell RTH230 thermostat. Ive read the manual top to bottom and have set the temperature to 70 degrees and followed all the directions. But my home is still almost 85 degrees, and even hotter...
i am assuming the unit is coming on and all... there could be an issue with the refrigerant in the system such as a leak.. need to make sure the indoor fan is coming on and also that the outside unit is coming on..there are 2 copper lines at outside unit that are refrigerant lines the larger one should be cool and the small line should be warm.. there also should be hot air blowing out of the outside unit... if this is not happening you have a problem with either the freon has leaked or the compressor may not be coming on inside the outside unit \
Jul 20, 2011 | Honeywell Programmable Thermostat Heater
The unit does not blow cold air any more. Inside is sometimes hotter than outside. will be 85 inside but 80 outside. Have thoroughly cleaned filters, but no change. "comp" light is on
Hi, The compressor has gone bad and it will cost more to replace it then the unit is worth... buy another unit and buy anything BUT an Amcor unit... they are junk!!
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Amcor AF9000E Portable Air Conditioner
I had my a/c charged today because it has not been cooling the house down. It took less than a pound, but it still blows worm air. Fan and compressor all running. I cleaned outside unit, filters, replaced...
It could be that it is not charged correctly. Check the insulated copper
line outside if it is sweating and the condensor is discharging hot air, then the ac is doing all that it can. Check the evaporator inside to see
if the drain has condensate coming out of it.
Getting the heat out of the attic is a good idea, but you must have enough make-up air in the attic for the fan. If you do not have enough
make up air, it will start to draw air from inside the house. One way to check this is if you have a gas water heater and or furnace. If you put
a flame by the exhaust pipe in the basement and it blows it out, then you now have a backdraft problem.
Run the AC withoutthe fan, my real guess is the unit is not properly
charged or you do not have a big enough AC unit.
Jul 17, 2010 | Goodman CKL36AR36 Air Conditioner
Hi, I have an Armstrong A/C that blows cool air when the outside temperature is around 75 even up to 77. When it goes hotter then it blows just air. Is there a setting that needs to be changed in order to...
It could be that the unit needs to be cleaned, it could
be that the compressor is tripping on an internal overload because the internal part of the compressor
is surrounded by high ambint air. It does not sound like a freon isssue.
Jul 06, 2010 | Heating & Cooling
I have a Kenmore model 106.97710530 5,000 BTU unit that was given to me by a friend. I have no owner's manual. Is it hazardous to your health to have the entire unit inside? Does it have to have the back...
It may not be hazardous to your health, but it'll never work that way either. The back side has to go to the outside to discharge the heat that is being drawn out of the room. If you leave it inside, and factor in the heat of the unit running, the room will get hotter, not cooler. They do make extention cords specifically for window units. Check at one of the "Home Hardware" stores, e.g., Lowe's, H/Depot. That should get you chillin' in no time!
Best regards, --W/D-- Please feel free to rate this solution!
Jul 29, 2009 | Kenmore Heating & Cooling
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
Intertherm not cooling correctly
Sound like air flow problem to me, the inside and the outside. check the inside filter to see if it's clean and clean the outside condenser coils by washing it.
Aug 23, 2008 | Intertherm P3RA-048K Air Conditioner
Cooling problems
Check the filters inside and the evap coil to make sure it isnt filthy. The evap coil can be cleaned with a credit card if its wet. The large line outside should sweat all the way to the compressor if its got enough freon. Will freeze when its cool outside or not sweat at all if its low. Good luck with it.
Jul 30, 2007 | Ruud UAKA030 Air Conditioner
Heating & Cooling Logo
32 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
