Question about KDS Radius RAD-7 17" Flat Panel LCD Monitor
My monitor stays on for 6 seconds
Same problem: my 3 year old KDS 17in monitor stays on for 6 seconds then goes black. If I turn it off and then off, I get another 6 seconds. Hard to read my mail that way, but it can be done by turning the monitor off and on 100 times. What the f?
  • 1,684 Answers
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
Kds 700p monitor
The most common problem with LCD monitors is the capacitors that are on the power pack. the pack usually looses or pops as we say 2-6 of them after 3-5 years. its almost a certainty after 5 years. a component repair tech can replace these but unless you can find some one like me who will do it for cheap to save the landfill you most likely will buy a new one.
Mar 19, 2010 | KDS K717s 17" LCD Monitor
Monitor won't stay on. each time I turn it on it comes up for about 3 seconds and then goes black
aburnsrn, Cold-cathode-fluorescent-lamps don't light-up, you will be looking at black screen!! If unit older than 5-6 years trade for new wide-screen. Else read for about 2 hrs. in my fixya profile for more options.
12fixlouie
Feb 27, 2010 | Acer AL1917W LCD Monitor
Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Aug 14, 2009 | Samsung SyncMaster 920NW Monitor
I have a older kds lcd monitor that goes black less than 1 min after turning on, the power light stays on, the monitor will come back on if you repower the monitor then goes back off in 3 or 4 seconds. Is...
if you look closely can you see a very dark image on the screen? your problem is usually the result of the backlight on its way out, these are very hard to replace so you will need to take it to a profesional, in most cases it is cheeper to buy a new screen.
Jul 02, 2009 | KDS Computers & Internet
Monitor connects and displays for 2 seconds, then blacks out.
I would suspect an electrical component is failing. Try your monitor on another computer and see if it does the same thing. If it does, the monitor is failing. Also/Or try another monitor on your computer. If the new monitor does the same as the old monitor, then maybe the video card in your computer is failing. Try a new video card. Keep trying different component combinations until you decide what has to be failing.
May 30, 2009 | KDS Computers & Internet
KDS 715S monitor is black and will not turn on
It might be a signal issue....try checking your 15 pin cable,
Apr 11, 2009 | Computers & Internet
MAG Innovision LT2219WDB monitor will turn on -picture up clear as ever and 2 seconds screen goes black, turn it on and off screen comes up clear as always and 2 seconds goes black. will not keep the...
I have the same problem with a customer's monitor (LT716S); it turned out to be damaged power supply board. As I understand it, MAG has a 3 year warranty on parts, will probably charge you a flat labor fee plus shipping. If you do not have your purchase documentation for warranty, dump it and replace. If you can, then you may wish to have it repaired.
My customer replaced theirs; I am trying to purchase replacement parts to repair...good luck.
Feb 24, 2009 | Computers & Internet
I have an HPW19 wide screen monitor that goes to black.
I have the same monitor and it is only 3 month's old, the power lock button continues to fail and they have replaced it 3 times with the same issue, What a piece of ****!!!!
May 26, 2008 | HP w19 19" LCD Monitor
KDS Radius RAD-7 17" Flat Panel LCD Monitor Logo
326 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
