Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Sound is gone from all inputs
Can not get sound from the system from any input. I suspect the audio section of the TV has failed. Has anyone heard of any problems like this for this TV or am I just lucky.
Jeff
  • 87 Answers
BAD digital board. Need to match digital board to DMD board. Too expensive to fix, just buy $200 dvd/stereo system. Better sound than the 3" speakers in the tv
Posted on Jan 03, 2008
I hooked up my soundbar using the HDMI out (TV) port from bar to HDMI in port on my Philips TV power is on bar however I can't get any sound out of bar. But just audio cables worked what to do?
OK, If its the Samsung Sound Bar, this item should have 2 HDMI input, 1 3.5mm audio jack input and a digital audio input (fiber optic). Since there are various input, the remote control should have a source button, or it will probably read O/A Input, this is to change thru the inputs from the sound bar. If you connected your TV HDMI output to HDMI 1 from the Sound Bar, then press the source button to reach HDMI 1, maybe it will be display with a different name, like sound 1, or DIGI.1 Give it a shot and let me know in the comment section. Good luck.
Dec 19, 2015 | Samsung HW-H450 2.1 Channel 290 Watt...
TCL television-sound is gone!! Hi, kids were in the middle of watching a movie and sound stopped.. Turned off and on, checked all plugs, tried all channels..still no sound :( does anyone know what may fix...
Check whether the "Mute function" is activated or not. If activated, de-activate it. As you know, if it is activated, there will be no audio output to any input feed to TV. Get into its menu and check this first.
If it is not activated, feed the TV by external Ariel input. and check whether any of the channels that receives have sound output. If yes, check the system settings. If your TV is a multi-system one [ie PAL/SECAM/NTSC etc:]; if the system have changed there will be no sound, as well as the picture too will be dull. It will be best to make this adjustment to AUTO; as it will make the set to determine the system of signal it receives, and will change to it automatically.
If all these are OK, and still there is no sound, something bad have happened. If so:
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Oct 22, 2014 | Televison & Video
The sound does not work in my tv. Can you help?
Please check the input to the TV. connect a DVD or source to the input line and see if there is sound . If not the output section seems to be faulty. Also check on the audio ouput of the TV - connect to amplifier and if the TV sounds are heard then the preamp is good as the fault seems to be with the power output amplifier.
Check the power section, check the audio output IC.use of multimeter and signal injection will be needed or you must take help;
Sep 13, 2011 | Digital Lifestyle s LT32323 LCD TV
Sound is fuzzy on all stations and video modes
More that likely you are using the internal speakers for sound. There is an output IC (Integrated Circuit) that processes and amplifies the sound. If that fails partially you will get fuzzy sound, also the speakers could themselves be causing the problem. If you have an external Audio out try running it through an external amplifier if the sound is clear then the problem is the Audio output section...
To accomplish this connect the Red and White Audio OUT to the stereo. Use an audio patch cord and plug the cord into the amplifier using any input (you must select that input on the front panel) except a phono input.
May 30, 2010 | Sony FD Trinitron KD-34XS955 34" TV
LG tv sound quit - will it work if I add external speaker system
Maybe!! It depends on where the audio sys failed. If it failed at the output drive, then you can take the audio off at the audio output jack and input it to your stereo system where there is an audio input. You'll need a cable with RCA jacks on it for this.
If your system is muted for some reason, this may not work.
May 16, 2010 | LG 32LB9D TV
How do I get surround sound while watching my t.v. I'm trying to hook my t.v. through my receiver
you should have an audio out jack / jacks on your tv. run wires from the outputs on the tv to your reciever imput. on the receiver you probably have multiple choices of imputs. select an auxillary or better yet the tv input for the audio.
set your amp function to whatever channel you inputed the tv audio.
chances are you will not hear sound from the tv, but it will be heard through your amp speakers.
Feb 21, 2010 | Audio Players & Recorders
Why cant I supply my onkyo surround sound system
You need to assign the HDMI input(s) to the functions they represent, using the Front Panel Tuning/Preset control...
If you connect a video component to an HDMI input, you must assign that HDMI Input to an input selector in Setup.
For example, you could assign the “DVD” setting to “IN1”, and assign the
“CBL/SAT” setting to “IN2”.
Likewise if you use digital audio inputs...
Assigning the Digital Input
If there’s no sound, press the [DIGITAL INPUT] button repeatedly until sound is heard. The digital input is now properly assigned.
If you connect your DVD player to the AV receiver’s COAXIAL 1 DIGITAL IN, and your cable/satellite receiver
to the COAXIAL 2 DIGITAL IN, as shown, it’s not necessary
to assign the digital input.
Feb 12, 2010 | Onkyo HT-S5100 Theater System
Hook up sony blu ray
You should be able to hook it up with a component video cable. A component video cable is a cable that has 5 color coded RCA style ends that are Green/Blue/Red/White/Red. The Green, Blue and one of the Reds is for the video and delivers the signals needed to produce the HD picture and the White and the other Red is for the audio to provide you with stereo sound.
The Video cords will plug into the section labeled component video facing up and down and the audio will plug into the side by side section. So if you plug into Component input 2 then you would plug in the audio into the audio section of input 2.
If you have a separate surround sound system you can connect one of two ways.
1. Plug a separate Audio (red/white) cable from the Blu Ray to an available input on the surround sound.
or
2. Plug all inputs into the TV (as noted above) and then plug a separate Audio (red/white) cable from the tv labeled "Audio Out" to an available input on the surround sound system.
Jan 03, 2010 | JVC AV-48WP30 48" Rear Projection...
No sound the speaker is good as well is the amp. what is the problem?
if your tv has audio/video inputs try watching some dvd movies ir sound is heard by using your audio/video setup the problem most likely is your sound IF section or your switching ic that selects your av/tv mode is deffective
Oct 14, 2009 | JVC AV-27720 27" TV
Installed new 1080 plasma tv can't get sound from home theater system
A home theater system usually consists of a dolby digital stereo amplifier and 5 to 7 speakers.
Turn your stereo on and select the source that delivers video to the TV (DVD, VHS, Game, etc.). The video may be connected directly from the device to the TV, but the audio should connect to the stereo system (DVD, VHS, or other input). This way, the source audio is sent to the stereo and it provides the big sound to match the picture. Otherwise, you'd have to connect the source audio to the TV and let it's comparably tiny amplifier and speakers provide sound - that comes up short.
When playing a DVD, select the DVD input on the TV *and* the DVD input on the stereo. If you do not connect the audio to the DVD input on the stereo system, you'll have to connect to the TV, otherwise nothing will be heard.
Sep 17, 2009 | Audio Players & Recorders
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
