The machine won't run in any cycle. It gives a loud buzz.
If the buzzing is coming from the bottom of the machine, then first check to see if any lint has accumulated in the filter area. If that is clean, then it is probably a defective drain motor. The first thing an LG washer does is to try to drain any remaining water from a previous load from the tub. If the impeller on the motor wears out, it will start to wobble, not pump any water, and causes the vibration/buzzing sound.
Pc board
SOURCE: 7 kg intellowasher noise when in wash cycle
if its a direct drive remove the rotor and see if theres a loose magnet etc,hope this helps
SOURCE: LG Tromm 8/4 WD R8012
The manual suggests to shut the water off ,
remove the inlet hose and check the screen for blockage.
The ie message is the inlet water is insufficient.
SOURCE: Bad smell in our washing machine LG Front Loader WD-8074
You don't have to drain all the water out after each use, you just need to clean things up a bit.
There is a problem with the design, in that the drawer area is a breeding ground for mould.
There will be a latch on the drawer you need to press to remove it - take it out and wash it in a hot solution of borax. Alternatively bleach it, and then wash in hot detergent.
Use a spray cleaner designed to kill mould and mildew, and use it with a brush inside the drawer apature to remove all mould build up. It's quite a grotty job - but needs doing.
After that, use a cloth to clean as far back into the pipe as you can.
Do two washes on hot with bleach, then a rinse, and it's good to go.
It is most important you leave the drawer open after a wash, and the door open more than 2" on these machines to prevent it, and a hot wash occasionally for whites. Tell the manufacturer that you won't be buying their brand again.
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
SOURCE: I have LG TROMM WM1812CW soap leaks out from
For the owners manual go to
http://www.lge.com/us/appliances/washers/index.jsp
and search for your owners manual by part #
