Question about Toshiba SAT PRO P300 PC Notebook
Hi i have window vista and when you go on it ,it freezes but will work in safe mode can you help
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
If you have installed any new hardware or software recently, uninstall this while in safe mode.
If you have not installed any new hardware or software, try to do a system restore to an earlier date. You want to choose a date when you are pretty sure you were not having any issues logging in. Doing a system restore will not bother any docuements or emails that you may have, but if you have installed any new software, this will need to be reinstalled.
1. Click start, type System Restore, hit enter
2. Follow the wizard to restore your system to an earlier date.
If this does not work, try to limit what starts up when you log into windows normally.
1. Click start, type msconfig, hit enter
2. Click on Services Tab
3. Check hide all microsoft services
4. Click disable all
5. Click apply, and click ok, exit out of this window
6. Try to boot into windows normally
7. If you are able to, then you know that it is a start up service that is not allowing you to log into windows correclty. If this is the case, then go back to step 1, and reenable half of what you disabled, try logging into windows. Keep doing this until you are able to isolate what is causing the issue.
8. If you are still not able to, it may be a windows start up service that is causing the issue.
All the above can be done from safe mode.
Hope this helps.
Posted on Jul 03, 2009
HOW CAN I UN FREEZE MEDION TABLET
When your PC Freezes this is usually a form of Malware causing your PC to freeze.
Try booting into safe mode with networking:
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
(Choose Safe Mode Withnetworking)
Once in Safe mode Run a Full Scan with Malwarebytes
http://www.bleepingcomputer.com/virus-removal/how-to-use-malwarebytes-anti-malware-tutorialFollow steps on installing, updating and running a full scan with Malwarebytes.
Aug 17, 2012 | Computers & Internet
MY ASUS F80Q WONT start up, it stuck in the Microsoft corporation
Hi. First option: For that symptoms try restart PC then before booting press F8 to see.(for windows xp professional and home edition. operating system )
safe mode safe mode with networking safe mode with command prompt enable booth logging enable VGA mode last known good configuration (your recent settings that worked) select this option by highlight then press enter key. if same problem? restart PC again then select safe mode wait for booting. already use that option not yet happened same problem. jimmyverdade_46.jpg
Second option:You need to reinstall fresh installation of operating system like windows xp,windows vista,windows 7 version etc.
Hope can help you.
Jun 17, 2011 | ASUS F80Q-X2AM Notebook
I have an HP Pavilion a6647c desktop computer, running Windows Vista. Only 1.5 years old (bought 3/2009). when we try to turn computer on, IF we get to Windows logon window, it will freeze right...
Hi There,
Your problem has likely only 3 sources.
1. Corrupt Boot Files in Vista
2. Virus
3. Hard Drive locking up.
PLease boot into Safe Mode, download Malwarebytes Free Edition malware remover, stay in Safe Mode and run it there.
If no viruses are found for you to remove, you nedd a Vista Program Disc. Boot from the Disc and use Repair.
If no luck there, return to Safe Mode and use Sytem Restoego back to the earielst point in time in the past when you remember you puter running correctly.
Failing in all these, you likely need a new hard drive and start fresh.
Remember,
DON"T SHOOT THE MESSENGER!
Regards,
Selk
Nov 19, 2010 | HP Computers & Internet
How can i troubleshoot why my windows vista machine freeze ?
System freezes can be caused by many different things but are more likely to be caused by the hard drive having bad sectors or the system files are corrupt.
To troubleshoot the system files and hard drive i recommend that you boot the machine up in safe mode. To do this restart the computer and repeatedly tap the F8 key. When you get to the sub menu select "Safe Mode" and press enter.
You will see a boot leader apear (white text) on screen, wait until it loads the welcome screen.
Once inside safe mode you will notice that you have no sound, internet connection, desktop background or graphics. This is because in safe mode the system only loads basic drivers so the above mentioned are dissabled allowing you to work in safe mode.
Click on the Start menu (orb) and in the search pane type cmd and hit enter. A command line window will come on-screen.
Type in that command window chkdsk /f /r and hit the enter key.
You will see information about the volume with a message that the volume cannot be locked, would you like to schedule a disk check next time the system restarts? type Y and hit enter and then type exit and hit enter.
The window will close so then restart the computer.
When the system restarts let it boot normally and now the system will check on the hard drive and check system files for you, if it finds any problems it will fix them itself.
This proceedure can take anything up to 2-3 hours to complete so please be patient.
Good luck and if there is anything else i can help you with please post back.
Regards.
May 27, 2010 | Microsoft Windows Vista Home Premium...
Toshiba A135-S4467 runs in safe mode but not normal (Vista)
The fact it starts in safe mode (which means it loads the basics for the pc to run and thats it) would indicate to me that there is something running in the backround at normal boot and also your cpu has a panic attack. Just wondering did this pc come with this version of windows or is it one you downloaded and installed yourself?? If its one you downloaded yourself (which it sounds like) get rid of it, because it is probs corrupted. Get another copy of it or to be quite honest I would get windows 7. Its better ,faster, and a lot less **** runs on it...The fact you changed your hard drive and still have the same problem it sounds like the copy of windows you have...Hope this helps...
Oct 10, 2009 | Dell Inspiron 2200 Notebook
Installed AT&T Communication Manager on ACER 5335 now it freezes
enter safe mode and uninstall the ATT software..reboot.
http://www.aa1consulting.com
Jul 26, 2009 | Microsoft Windows Vista Home Premium with...
Vistro 200 destop keeps freezing
Download avast and run a boot time virus scan. remove all detected viruses. if that doesn't help, reboot, insert your windows vista recovery disk, and reinstall windows.
May 09, 2009 | Dell Vostro 200 PC Desktop
PC notebook will only start in safe mode.
Try doing a System Restore, once you have booted up in Safe Mode, to a time before you had the problem.
Hope this helps
Chris (ziraffa)
Jan 02, 2009 | Computers & Internet
Windows Vista Freezes during Boot process
while in safe mode with network connectivity, go to trend micro website and do a free online scan. If you have Windows Defender updated, then try a full system scan, also while in safe mode.
Jul 13, 2008 | Computers & Internet
Toshiba SAT PRO P300  PC Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
