Question about Pool & Spa
Jacuzzi magnum force inground pool pump trips breaker
  • 128 Answers
Check amps if you can. If the amps are higher then the amp rating on the pump replace the pump. If the motor won't run. Replace it
Posted on Aug 23, 2009
My jacuzzi magnum force pump is hot is this normal?
the pump is pumping and circulating hot water into jacuzzi, it will get hot. I think it is ok
Jul 06, 2012 | Jacuzzi Magnum Force Series Pool Pump 1...
My jacuzzi clicks like it is going to start but does not.
If you have the proper voltage into and out of the time clock, you may have a bad start/run capacitor. I would need to know if it hums and then trips the breakers and if the shaft is free to the point you can turn the impeller with your finger.
Jul 18, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
I need a motor end cover, where can I get one? Thank you!
Jacuzzi (Carvin) Magnum, Force & Plus pump parts are hard to find.
Here is a link to our site which has a parts explosion/diagram for those pumps.
Jacuzzi Magnum, Magnum Plus, and Magnum Force Pumps
Jun 08, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
I do have inground pool 16 *32 10 feet deep at one end and 4 feet at front, The pump did not start at all when i started it. Since the pump is an old pump above 15 years old I decided I would buy a new...
I'd suggest the 1.5 HP Hayward Super Pump, model SP2610X15. It's layout makes fitting it into the footprint of the Jacuzzi easier since it's ports roughly line up and are smaller in spread than the jacuzzi. Any pump will require some monor replumbing; the Haywards should be the least intrusive.
Another good choice would be the Pentair Whisperflow in a 1.5HP with or without the variable spped features.
John
May 01, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Magnum 1000 - overheating & looking for manual
Loosen the motor and impeller from the pump by backing off the large plastic nut and take that whole section to an electric motor repair shop for inspection. If the motor is salvagable, they can quote the repair or replacement.
Jul 05, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Magnum Force Pump not working
The number one problem is air leaks.......check all connections to see that they are tight, and rubber seals. The intake side would give you trouble with air leaks. If you dont find any leaks then I would pull the pump cover and check the impellor. Pool stores have parts and lots of knowledge.
Jun 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi - GFCI keep tripping prventing Jacuzzi from starting Jacuzzi Whirlpool Bath, model H240000
i have the same model after unplugging everything one by one i got the breaker to stay on with the transformer unplugged. ordered new transformer installed works great!!
Mar 28, 2009 | Jacuzzi ALADDIN GO-KIT14 JACUZZI MAGNUM...
Do Magnum Force Pumps have a reset switch ?
No jacuzzi magnums do not have a reset button. First make sure breaker to pool is off, then remove rear motor cover, and take a look. Popping noise sounds like an arked wire. Could be a bad terminal or just aloose power wire. JACUZZI PUMPS ARE GOOD QUALITY, AND USSUALLY RUN FOR MANY YEARS. Pump can be removed for repaair, or motor replacemant by a qualified, and republe pool shop, for rebuilding Ussually rebuilding is about half the cost of new. Kirk
Feb 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Magnum Force Jacuzzi Pump stopped working
No serviced by pool technician. But you can look in your breaker box for a popped breaker, it should be 20 amp and be positioned in the middle instead of on or off position. Kirk
Dec 28, 2008 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Pool & Spa Logo
106 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
