Question about Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
No readout on the display panel - Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas
    Champion:
  • 246 Answers
Not power to the system check for voltage if 220 or 110 check the fuse
Posted on Oct 15, 2009
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
Bench supply volt meter readout malfunction
you did not supply model or manufacturer
google for manual (unlikely to find if it's a cheep model)
Feb 07, 2014 | Televison & Video
Z9 panel is missing some display
1) replace the batteries and clean the contacts batteries.
2) adjust the REED swtich, clean it, and tight the connector very well.
God bless you
Nov 11, 2012 | Exercise & Fitness
System works fine, plays well etc. However, the digital readout is no longer visible. Ideas?
There is typically a dimming feature among these types of systems. There may be a button on your remote/system panel to adjust how dimmed the display through which you can adjust it. If not, then try to enter the system setup mode and adjust the brightness of the display.
OR if the digital readout is not very dim and is in fact blank then your LCD panel has failed. You should replace the panel or get a new receiver. I would start by calling the customer support line as this will surely be under the manufacturer's warranty.
please rate my solution
Jul 31, 2010 | Bose Lifestyle 25 System
Changing temp readout on Midea Air Con Controller from F to C
  1. Make sure the unit is NOT on lock mode
  2. Press reset button for 2 second or until the Flashinf "F" appear on the temperature display or panel.
  3. Press Add button to change from Fahrenheit"F" to celius "C".
  4. Then press confirm and then cancel button to finish.
Jul 09, 2010 | Heating & Cooling
No readout on front panel. UVW-1800
No front panel readout on a UVW-1800 is caused by the audio bargraph display failing. This display has an auxiliary power supply in it that provides power to the front panel display.
Oct 15, 2009 | Sony Televison & Video
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Display stopped working
My Alpine CDA-7842 works fine from a functional point of view but the display (readout) had stopped working. All the lights on the display work but the actual readout is blank. At first the readout would intermittently work now it's completely dead. Any assistance would be greatly appreciated.
thanks
Oct 26, 2006 | Alpine CDA-7842
Jandy Laars LX Pool Heater / 400,000 BTU / Natural Gas Logo
161 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
