Question about Garden
Troy Bilt power washer/Briggs and Stratton 675 series engine Engine will not start, used twice last year. New fuel, good spark. When starter spray is used enginme fires and runs 2 or 3 seconds until spray burns off. Checked fuel line, good.
    Brigadier General:
  • 3,614 Answers
Check the fuel pump & also the fuel filter, this could be clogged with dirt.
let me know
Posted on Jul 03, 2009
Hard pulling starter rope
You say Pull rope mechanism is ok, How do you know that? Ive's seen them get the rope a little off and gets caught being wedged into a small clearance. Is the rope wearing? I bet if you take it apart put a new nylon rope and some wd-40 in rubbing surfaces including the ratchet area it will be good as new. Crank bearing has to get really bad to effect pull. How is the spark?
Mar 13, 2015 | Troy-Bilt Troy Bilt Chipper Vac Plus Parts...
This is a Troy Bilt Big Red Horse Tiller. Wont crank. new battery. ignition switch good. starter relay clicks when ignition switch turned. jumpering the relay makes the starter spin.
The starter solenoid/relay clicking can mean a bad starter solenoid/relay or bad grounding. Not knowing what engine you have as they have used Kohler, Tecumseh and Briggs and Stratton over the years. hope this helps
Mar 06, 2015 | Troy-Bilt Garden
Briggs and Stratton 10T500 engine will run on prime fuel only. Carb not supplying fuel. Small carb tube that dips down into fuel tank seems unobstructed. Tank full of new fuel. Exhaust muffler is...
make sure that the inline fuel filter is clean and thenremove carbeurettor make sure all the jets are clean then reset the idle jet to 1.5 turns from closed, replace everything bada bing bada boom shell run like a champ.
Oct 27, 2017 | Briggs & Stratton Garden
I have a briggs & Stratton 675 series engine in a Craftsman front wheel drive rotary mower which won't start. It was fully serviced and used 3 times this season but now it won't start. It
if it has hit a object, the flywleel key is partially sheared, and needs to be replaced. they are very inexpensive,CHEAP. this will through the engine out of time just enough it wont start.
Apr 16, 2013 | Briggs & Stratton Garden
I have a Troy Bilt 2550 psi Power Washer with a Briggs and Stratton 675 Series, 190cc engine. Could you tell me what kind of oil I should use.
Best oil for small engine for most moderate climates is 30wt non-detergent. The pump can use mineral oil (air compressor oil ) sold at most auto stores and lumber outlets.
Jul 02, 2011 | Garden
My troy bilt 2500 pressure washer won't start. I have replaced the fuel, changed spark plug, & used carb starter. will kick over but will not continue to run. the washer is only about 1-2 years...
A YouTube video posted in December 2014 reveals TroyBilt only markets these; they are made by Briggs & Stratton and they use PLASTIC CAMSHAFTS and PLASTIC TIMING GEARS and that these are failing en masse. WTF?? In an engine that gets hot??
Jun 18, 2011 | Garden
Tory bilt lawn tractor replaced with new battery
What most likely happened is the diaphram in the carberator has burst. It is a simple fix if you take your time, use reliable resources and be patient. The parts can be picked up at the local hardware store.
Mar 25, 2010 | Briggs & Stratton Garden
Troybuilt 675 hp lawn mower doesnt start
self propelled not working on troy built 675 series bought 5/08. The belt is still on.
Jun 17, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt power washer 020293- Oil in air filter
that is incorrect. if the oil has been over filled, it will saturate the filter element by way of the crankcase breather tube. it is the small plastic pipe that connects to the bottom of the filter housing. check the oil level. these machines take very little oil. approx 20 oz. if overfilled, it will leak out filter.
May 10, 2009 | Briggs & Stratton Pressure Washer...
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
