Question about Seiko Arctura Kinetic Autorelay #SNG067 SNG067P1 Watch for Men
After replacing the capacitor in my 5J32-OAPO the
After replacing the capacitor in my Seiko Arcura Kinetic 5J32-OAPO the second hand no longer revolves - I removed and replaced the capacitor a 2nd time to be sure but to no avail. - The time hands and date display are working normally. Any suggestions please?
  • mjd_etc Mar 07, 2010
    Thanks for taking time to reply ron3770 but I did not remove the movement from the case!
    Scholar:
  • 110 Answers
It is possible that the second hand is touching the crystal. However, this probably would have only happened if for some reason you remove the movement from the case and in putting it back in it now touches the crystal. If this is not the case, then I am assuming that you have pushed the crown all the way in. Please let me know if any of this works for you. I don't know of any reason that replacing the capacitor would only affect the second hand.
Posted on Mar 07, 2010
Charge indicator on my Seiko Kinetic watch does not work. Watch keeps good time. Is there a fix?
Bill, when you say "does not work" I am going to guess you mean that the second hand does not sweep as it should, so you do not have an accurate indication of remaining capacitor charge.
There are many other malfunctions of the Indicator on a Seiko Kinetic but I am guessing that is your current watches malfunction.
The button at 2 o'clock depresses a tiny lever inside the watch, and that in turn releases a discharge from the capacitor.
The strength of that discharge swings the indicator.
The lever itself is very very small, and can be misaligned, very commonly after capacitor replacement.
Actual breakage of the lever is quite rare.
Does the button have a definite detente when you press it?
Or is it instead like pushing on Jello.
Is the button spring loaded such that it returns to the neutral state on its own?
It is actually a quick diagnosis for anyone familiar with Kinetics; as a quick peek will tell if a broken lever, absent button gasket, need of lubricant, etc.
Aug 08, 2016 | Seiko Kinetic watch
I have purchased a new Seiko kinetic SUN007 mens watch. After hours of swinging back & forth to charge the watch, the 'second' hand still moves in two-second increments. (After charging via movement,...
I have a Seiko kinetic watch and it has behaved perfectly for over two years and therefore I think that yours is faulty.
I suggest you send it to Seiko to have it repaired or replaced under warranty.
Apr 05, 2011 | Seiko Sun007 Kinetic Watch for Men
I do not know how to wind up my watch, while a swing to a later no.Please answer me.Model hours a Seiko Kinetic 5M62-0B40.Thank you
This watch operates on a capacitor which is charged by movement. It does not wind, but it has a weight that charges the capacitor by motion.
Take the watch in hand by placing your fingers under the caseback and your thumb on the crystal. Use a horizontal motion (landscape) to move the watch back and forth quickly approximately one foot left and right. You should feel the internal weight move.
Do this for at least five minutes. If the watch does not start to operate (the second hand does not move at one second increments) then either the capacitor must be replaced, or the movement is defective.
You may send the watch directly to Seiko for service, or I would strongly suggest visiting your local Certified Master Horologist for what is usually a free assessment and estimate of the repair.
If you are following the above directions, you have done nothing wrong, but the movement or capacitor needs to be replaced.
If you have just purchased this watch and the instructions do not resolve your situation, I would promptly return it and exchange it, as the model may have been sitting for a while, and have a bad capacitor.
Feb 23, 2011 | Seiko Kinetic watch
My seiko is keeping good time but the second hand jumps two seconds then hesitates for what seems to be a second then skips two seconds again
There are three solutions for this problem, contingent upon the model:
With both instances, this is a power saving / low charge / low battery feature of the timepiece.
1) Is your Seiko watch a Kinetic / Solar model? If so, your watch contains a capacitor. The capacitor may be bad, OR if you have not been wearing it on as regular a basis, wind the watch (Kinetic) vigorously for 5 minutes, and if the second hand returns to normal function, the capacitor is most likely fine. If is is a Solar model, expose it to sunlight for 4-6 hours or incandescent light for 24 hours and see if this resolves the problem.
2) Else: if this is a standard battery operated watch, take your watch to an authorized Seiko repair center, or Certified Master Horologist. Make sure that the Seiko Repair Center is using Seiko batteries, else make sure they are installing Energizer only - these two batteries will not leak in your movement. Avoid other batteries at all cost, many of them will leak and ruin your movement.
3). If these solutions do not work, and you have not had your watch serviced in the last 3 to 5 years, you need to service the movement. See the aforementioned parties to begin the process.
4) If your watch is water resistant, and/or you plan on wearing it in the water, make sure to have your watch water tested by the appropriate aforementioned professional to ensure it will withstand proper dynamic and static pressure at the appropriate depths.
Feb 04, 2011 | Watches
Seconds hand stops moving
1st reason. This means your oscillating weight and paired gears are not generating enough power to charge capacitor, thus not be able to move hand properly. 2nd reason. Capacitor can not recharge itself to full power and needs to be replaced. 3 reason. Seconds or chrono wheel has a mechanical fault developed over the time and needs to be cleaned or replaced. Those are 3 reasons why the seconds hand stops moving in Kinetic watch. Which one is right, you will find out only after visiting watch repair shop, because I can not give correct estimate without seeing the watch myself.
Rate me, plz.
Jan 11, 2010 | Seiko Premier Kinetic® Perpetual Watch for...
My watch runs too fast: adds appr. 1 minute every 24 hours
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
Oct 03, 2009 | Seiko Kinetic watch
Can I use an ordinary button cell in a seiko kinetic
I have been trained by a Master watch maker and I have worked on many Seiko Kinetic watches. Yes the original watches came with a capacitor that is charged by your arm movement. But unfortunately, they seem to only last a few years. All replacements are now done with a Lithium Ion battery that is much better and lasts longer than the original capacitor. This is the correct solution and don't try to use a battery type that is used in other quartz watches.
Oct 01, 2009 | Seiko Kinetic watch
Second hand moves three seconds at a time
You have to replace capacitor in your watch. After that it will run like new.
Jan 03, 2009 | Seiko Kinetic watch
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Jun 27, 2007 | Seiko SKA192 Wrist Watch
Seiko Arctura Kinetic Autorelay #SNG067 SNG067P1 Watch for Men Logo
640 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
