GN switched from English text to Bulgarian. cannot read Bulgarian, so am at a loss to correct problem.
SOURCE: garmin 760 not in English
Hi, from the "Where To" / "View Map" screen, select the tools (spanner icon), then Settings (spanner icon again) then Language (Mouth icon).
There should be 3 options, the lower left is the Keyboard; select this then scroll to British English. The upper icon is the Voice, choose a suitable one (if it says (TTS) it will read out street names as ir gives directions), the top-right option is Text, again choose British English.
SOURCE: Foreign language text on GPS device
Click on the wrench tool button, then the picture of the sprockets which is system, then click the lips/mouth. Once there, you should be able to change the voice and text to English. Just click on one of the boxes to change it to your chosen language.
Press Wrench.
Press the button with the picture of gears on it.
Press Down arrow.
Choose second menu item from the top.
Press the middle of the 3 boxes on the right.
Press up arrow to find American or British English.
SOURCE: how can I switch my Garmin Nuvi back to English
Hi, I own a nuvi as well and the menu structure is as follows
tools(1)>settings(2)>language(3)>text(4)
the icons as follows and their location on the screens
1) spanner - bottom right of screen
2) spanner - top left of screen
3) mouth - bottom centre of screen
4) box on top right of screen
SOURCE: Garmin Nuvi 205 continues to state Loss Satellites
If your Garmin NUVI 205 can be recognized by your computer when plugged in, I recommend you backup your favorites.
Then I suggest a hard reset. This correct some problems.
Finally, replace the firmware and system software using webupdate. Replacing the firmware should allow it to find more satellites more quickly and keep them more successfully after the update.
I hope that helps.
