Question about RCA RP5020 Digital Voice Recorder
No response My recorder will not respond to any of the controls, except that it will lock when I hold down the menu button.
  • snack31 Nov 10, 2007
    Let it sit for about 6 months and the batteries leaked.. Removed them and cleaned it - put in new batt and now the only thing the menu button will do is lock if held for three seconds.
  • black girl Dec 07, 2007
  • 3 Answers
RTFM You need to press the play button to turn the unit on. Then the menu button works as advertised.
Posted on Nov 10, 2007
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
Mar 31, 2014 | Samsung Refrigerators
How do you turn off the FPA lock on the RCA TRUFLAT TV? I Can't access menu.
Hello
First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps.
* Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released".
** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released.
*** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
Mar 11, 2012 | RCA TruFlat 27F520T 27" TV
Every time I press the button to open it it is locked
This feature is provided in order to avoid accidental key activation during recording or playback.
1. Press and hold MENU for three
seconds, LOCKED will flashes on display. (LOCK icon will be shown)
2. Press and hold MENU for three seconds again to unlock keys.
May 04, 2010 | RCA RP5020 Digital Voice Recorder
Passlock
turn key all the way on (not to start) let set for 1 hur cycle key and try it.
Jul 20, 2009 | 1999 GMC Jimmy
New Sony DVDVCR RDR-VX560 seems to be locked up
Problem was solved by Holding down the "ENTER" button for no less than 10 seconds and after releasing it press "SYSTEM MENU". This will take you to the setup screen on your TV.
where all settings can be made from there by following the on screen directions.
Jun 22, 2009 | Sony RDR-VX515 DVD Recorder/VCR
Menu Button not working, can't record
There must be some keys active after you press Menu. Like you said, it must be waiting for you. After you hit Menu have you tried all the numbers and arrows?
If you can't get any of them to respond (except hitting Menu again to exit the menu) perhaps you need to try a different manufacturer code for your device. For example, if you have Brand ABC Model XYZ, perhaps the valid remote codes are 012, 013, and 014. Even if you have found that 012 works for most things but you can't record, you should try programming the remote to codes 013 and 014 and see what happens. There could be slight differences between the codes that allow most features to work, but not ALL features, just as you are experienceing. Good luck.
Aug 02, 2008 | Radio Shack 15-2146 Remote Control
Manual for RCA voice recorder
to lock and unlock your recorder, hold down the menu button to lock, and also unlock, i think it can only lock while its off, so just hold down menu and you will see the lock on the screen disappear
Jun 17, 2008 | RCA RP5010 Digital Voice Recorder
Ddigital voice recorder rp5022b
The only way to unlock is to hold the menu button down for three seconds. This will lock or unlock the recorders functions.
Apr 25, 2008 | RCA RP5008 Handheld Digital Voice Recorder
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Proscan vcr plus gold stuck in lock
I just had the same problem and found a solution on the internet that worked. Hopefully you still have the VCR's remote control. Press and hold either the on/off, VCR1 or VCR2 button on the remote. I pressed the VCR1 button and held it for about 5-7 seconds. It released the lock and worked fine afterwards. The lock is some kind of childlock devise.
Mar 10, 2008 | Proscan PSVR73 VHS VCR
RCA RP5020 Digital Voice Recorder Logo
76 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
