I replaced all smoke detectors with new batteries and it still is chirping
It is possible that the battery is not contacting the metal clips inside. See if the can be adjusted out. More likely the detector is not recognizing the voltage of the new battery. You can try removing the detector from the ac power install the battery and reconnecting it to the ac. It should correct the issue.
They don't last forever. If they are more than 7 years old, replace them.
SOURCE: We have smoke detectors that are hooked up to
when you replaced the batteries it may unprogramed
SOURCE: just replaced battery in smoke detector and wont stop beeping
take it apart and looked for a silver metal, quipe it and it will be fine.
SOURCE: I replaced the 9 voly battery to the Smoke and
Can you pleas ensure that you have cleaned the unit as well. If it is not broken, that would be the probable cause. You can ask your local fire dept. to assist. They do that for free :-)
Cheers
TeaCii
If you own website, add
live support almost free
Real
security guard to watch your cctv for $1/day
