My compressor works itermittantly. I was holding suction line to see if it felt cold. It felt kinda cool. Then all of a sudden it went COLD. A minute or two later it was kinda cool again. Could my compressor motor be going off and on. If so, could a hard start kit help? Motor is cscr. Its on a Goodman 2 ton, r22 unit. Model ck24-1
  • 614 Answers
A hard start kit always helps. Take a reading inside. Temp at the return air and temp at the closest grille. Subtract and that temp should be between 19 to 23 degrees. If not you have other problems. Contact service tech for free estimate. Possibly a little low on refigerat, Rus
Posted on Jul 05, 2009
AC compressor clicks on and off while running?
the compressor will cycle on/off when the cabin temperature is reached
the larger pipe will be cold to touch as it is the suction line for the compressor
if you have a problem with the ac ,it will not work the compressor at all and the lines will not get cold
When in doubt take it to an accredited ac specialist shop and have the system check out.
Aug 11, 2015 | 2000 Cadillac Escalade
Mitsubishi ac keeps on turning itself off
If the compressor overheats, the clixon circuit will shut off the power to the motor to prevent damage. Then when it cools it will close the circuit and the compressor will again run to only shut down again.
The suction line going to the compressor should be cold - the cold gas returning to unit cools the hermetically sealed motor. If that line is hot you may be low on refrigerant.
Feb 19, 2014 | Heating & Cooling
HVAC American Allegiance 11 not cooling
The low and high pressure lines temperatures are backwards the large one should be cold and the small one should be warm. Sounds like a piston issue may be a restriction in the suction line
Jul 28, 2012 | Heating & Cooling
After installing my Klimaire 30912-H216 mini split, one of the three evaporators is cooling but not as much as the other two.
actually the hi side smaller line should be hot to the touch and the low side larger line should be cool or cold, sounds like a low charge without any further information, the small line coming off the compressor is the liquid compressed it should be hot, the large line low side returning to the compressor is the gas after the coils and returning it should be cool or cold depending on load
Jul 06, 2012 | Heating & Cooling
8 year old side by side, refrigerator and freezer not cold, compressor running, condenser fan running, discarge line not hot suction line not cold
discharge line not hot suction line not cold. This indicates the compressor is not working properly. It could be out of freon or just not pumping.
Nov 03, 2010 | Maytag Refrigerators
I have a kemore coldspot side by side maufacture date 04/07 that is not cooling properly. Freezer gets cold but won't freeze and fridge section gets cool. I have checked condenser fan runs and compressor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 24, 2010 | Kenmore 53642 / 53644 Side by Side...
Both the freezer and refrigerator are warm (Superba model). This happened all of the sudden. I felt the tank and lines at the back and the tank was hot and the lines were not cold. The fan motor is blowing...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 01, 2010 | KitchenAid Superba Architect KSCS25INSS...
Liquid line is cool coming from condenser indoor air not cold enough. Unit runs constantly at temps of 90 to maintain 80 inside
If the compressor is running at 90 there should be hot air coming out of the condensing units fan, if not it could be damaged valves in the compressor especially if the suction line is colder than normal like ice cold.
Obviously if the compressor is not running then you have other electrical problems.
Jun 02, 2010 | Bryant 463AAC005BA Air Conditioner
Heating & Cooling Logo
130 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
