Question about Hamilton Beach Water Cooler with Storage Cabinet
Water dispenser shut off
The cold water light will not turn off continues to run
Check to see if both fans are running. replace fan
Posted on Jul 05, 2009
On my water dispenser ylr2-5-87h3 has 3 valves red, white and blue .the blue valve will workpushing out cold water and then when it gets to cold it doesnt work anymore
Check your user manual for an over flow safety setting. it isn't uncommon on water dispensing refrigerators to limit the amount of eater dispensed at one time to prevent a stuck dispensing valve from allowing water to continuously run out all over the floor
Apr 03, 2016 | Refrigerators
Fridge's water dispenser continues to run
Hello John;
My name is Peter. I am a retired field service refrigeration technician.
Neither your ice maker or water dispenser work off your main control board.
There is only one reason that the ice maker will not fill and you water dispenser does not shut off immediately after the contact switch disengages.
Your problem is low water pressure. You have a bad water valve.
After time the water valve seals fail, metal form the water line or corrosion plugs the water supply valve. You need at least 60 PSI water pressure to shut off the water dispenser solenoid valve and at least 60 PSI to open the ice maker water valve and fight the long fill tubing resistance.
Check - Pull your unit out where you can get behind it. Turn power off to your unit. Turn the water valve off. With towels under the unit water connection and a large bucket ready, disconnect the water supply line. With the water valve shut off you will probably get a steady stream of low water flow. The valve is bad. If not, open the water valve with the water line in the bucket. Is the water flow 60 PSI? Probably not.
Use a hair dryer to completely dry the solenoid valve and electrical area before you plug your unit back in
You need to replace the valve.
Before you do the above. Just in case you move your unit check for a bend or closure in the water line.
Dec 24, 2014 | GE Refrigerators
Hot water continues to run from washer does not stop have to turn off hot water supply. Samsung front load one of the first models made
solenoid valve for hot water may be stuck or faulty. If you have a cold water supply, you may be able to run the machine using only cold water, turn off the hot water and keave cold on, see what happens.
Jan 08, 2013 | Washing Machines
Kenmore side by side refrigerator water dispensor will not shut off
Your water control valve is defective and will need to be replaced. Even though you hear the electrical part of the valve turn off the mechanical part of the control valve is stuck open causing water to continue to flow. What is your model number? Kenmore model numbers look like this example=> 312.234567 If you can find your model number I will show you the replacement part number, Thanks Sea Breeze
Nov 29, 2012 | Kenmore 18.3 cu. ft. Top Freezer...
The cold water dispenser in my whirlpool refrigerator stopped dispensing water about 2 years ago. Recently it just started dispensing water and does not shut of. I had to close the valve to the water and...
Hi copy;
You may like to try the Water Valve (Solenoid) sounds like it may had stuck once now has become free and stayed open allowing too continually flow. It is behind fridge where the mains water is connected into fridge... Cheers
Mar 16, 2010 | Whirlpool GS5SHAXN Side by Side...
Cold water will not turn off on maytag neptune washer
Check the solenoids at the water inlet valve. Use a multimeter or ohmmeter and check the solenoids for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Another possible cause would be a water level switch, but not with it running on only the cold water side. Hope this helps and best wishes.
Aug 30, 2009 | Washing Machines
Hamilton Beach Water Cooler with Storage Cabinet Logo
197 people viewed this question
Top Hamilton Beach Water Filters & Coolers Experts
fixits
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Are you a Hamilton Beach Water Filter and Cooler Expert? Answer questions, earn points and help others
