Question about Water Heaters
Whirlpool Water Heater flame goes out shortly after being lit.
I have a Whirlpool Water Heater that won't work. I can get the pilot light on, but when I set the heat for use, the flames will activate for about a minute before I hear a popping and hissing noise. Observing the flame through the view port, I see them flashing yellow-orange instead of blue. This increases for about a minute until the flame goes out completely. Help!
  • 3,053 Answers
Hello, sax
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about hot waterheaters and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/water-heater.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 29, 2011
    Problem Solver:
  • 16 Answers
This problem sounds as if gas pressure to the burner is to low, check mnfr's plate on heater for the correct burner manifold pressure, you will need a manometer or a guage that measures inches of water column, set the pressure correctly and the burner should stay lit.
Posted on Jul 10, 2009
  • nwagner42 Jul 10, 2009
Pilot light is lit but won't turn on water heater
What band and type water heater do you have? And about how old is the water heater? Add a comment with more information.
Following general information applies to tank-type residential water heater.
If pilot light is working, then thermocouple is good. Otherwise, if thermocouple was bad, or fallen out of place, then there would be no pilot flame.
Carefully read instructions for lighting water heater located on front of tank ... make sure you have the gas control valve set to ON.
At this point, troubleshoot varies widely depending if your water heater is older and air enters front of heater, or if water heater was made after 2007-9 and has sealed combustion chamber and FV system.'
Troubleshoot also varies widely depending if you have power vent and which type of gas control valve.
Copy following link for troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Also post detailed question on pro water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 16, 2012 | Whirlpool Water Heaters
My water heater pilot light won't stay lit
you need to clean the filters in the bottom of the water heater and have the thermal couple also check and see if there is a gas leak by spraying all visible gas lines if this doesent work then you more then likely need a new watter heater
Jan 17, 2012 | Water Heaters
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 21, 2011 | Water Heaters
Pilot light won't stay lit on new water heater
1) Get more air to the water heater and see if problem continues.
2) Read the following pdf-s for things that might apply to your situation.
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
3) Read pdfs above first, and then Add a comment with missing information below, for possible do-it-yourself help.
Does this water heater have a blower?
Is gas valve electronic? Or does gas valve have a dial?
If gas valve is electronic, have you checked outlet with circuit analyzer?
Did pilot light work correctly for a while? If so how long?
Where is water heater located? Hot attic? Closet? Garage? Is area dirty and dusty? Has air intake been cleaned?
What color is pilot flame? Clear blue or yellow-or-orange?
Have you inspected inside of combustion chamber for dripping water?
Aug 28, 2011 | American Standard 40 G Natural Gas Water...
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot light will not stay lit.
More than likely the thermal couple is defective. The thermal couple is a safety device that shuts the gas off if the pilot goes out. If it is defective the pilot light will not stay lit. The thermal couple is the device that the small copper line goes to. It is mounted beside the pilot flame and the flame much touch the TC for it to work. If the flame is not touching the TC bend it until it is in the flame. If it is touching the TC then replace it.
Jul 28, 2011 | Whirlpool Water Heaters
I have a Kenmore Power Miser 12 gas water heater that the pilot light keeps going out. The water heater has been in service for 45 months. The pilot light has a blue flame with some orange flame flares...
check and or replace the thermal coupling. the coupling goes into the main gas control, if the coupling is bad it will shut off gas supply. as a safety measure.
Mar 09, 2011 | Water Heaters
Water Heaters Logo
857 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
