Question about Paragon 4001-0G Defrost Timer
Problem with 8140-00, always goes into defrost mode or not freezing mode on freezer without any pins set for defrosting. All pins were removed since this device was going into a defrost mode and not automtically coming out.
2 Suggested Answers
  • 16 Answers
SOURCE: 8141-00-oem want come out of defrost mode?
You can contact Paragon (owned by Invensys Controls) Tech support at 800 445 8299 direct. When you call you will get an automated phone system. Navigate yourself to the defrost timer (not standard timers section) to get a tech rep.
Marty Walles is the most senior rep on these timers.
Posted on May 04, 2010
The freezer still goes but not the fridge part.
You have a unit whose defrost cycle isn't working properly. The defrost element is either controlled by an actual timer motor or it may be controlled by a circuit board. Either the defrost element is defective, the defrost timer is defective or the circuit board is defective. A very remote possibility is the defrost termination thermostat could be 'open'.
If you TOTALLY defrost the freezer compartment, your unit will work decently for about three days until it freezes solid again. The evaporator coil in the freezer is covered by the interior and inaccessible without removing the freezer shelving and the rear of the freezer interior. If the element is defective, it is located behind this cover and is imbedded within the evaporator coil itself.
Feb 20, 2015 | Refrigerators
After defrosting the freezer it will not cool
Don't panic about the hot sides of the freezer. It is quite common on all the freezer (make/model).
After defrosting, your removing the full temerature out of the system. It will take atleast 30 ~ 60 mins to come back to set temperature. This again depends on the load inside.
Jun 06, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
DEFROSTED WATER DOES NOT DRAIN TO PAN
Remove the food and the ice maker from the freezer ( if equiped ) and the bottom panel . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM or COPPER ( ground wire is good ) solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
May 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
True model gdim-26. runs fine unitl defrost then does not keep cold after defrost.
Hi, sounds like your defrost clock is stuck in the defrost mode. On most true boxes they have a paragon defrost clock with adjustable pins you can set the amount of cycles and duration of the defrost cycle. Find the clock and give it a turn in the direction of the arrow or cw. It will come out of defrost and start to freeze again. If it continues, you may need a new clock. Let me know what you find. Keep me posted. True boxes are top of the line
Sincerely,
Shastalaker7
Mar 23, 2010 | True 26 cu. ft. Commercial Freezer GDIM-26
Model GR2SHK/GRASHM - Fridge has water condensation on top of back wall. It is pooling on shelves and freezing. The fridge and freezer are set at the recommended settings. Thank you for your help.
You will need to remove all food and the ice maker ( if equipped ) . Slide out the freezer bottom , and remove the 2 ( or 3 ) screws holding the back freezer panel on , and remove the panel . Using a hair dryer , start in the middle , under the coils , and defrost until you see a hole ( defrost drain hole ) . Using hot water to help , defrost this hole until water starts to flow out . Get a short piece of hose , insert one end into the hole , and blow thru it , to blow out any unseen debris in the drain line . Then , get a piece of solid ( preferably aluminum , but copper will work ) wire , such as a large diameter ground wire , and insert one end as far as it will go , without any resistance , into the hole , and then wrap about 2 turns , around the black rod ( defrost heater ) just above the hole , When the refrig goes into defrost , the heat will transfer to the wire , keeping the drain hole from freezing up again .
Oct 30, 2009 | Whirlpool Refrigerators
MSD2656GEQ The coils on the freezer side ices up, then does not cool the refridgerator side
Hi, It's a common problem with no-frost refrigerators, you have a defrost problems, two scenarios. (1) hot air entering freezer/refrigerator, examples. hot summer days, regular openings, high room temperatures, hot foods and broken door gasket, leaving freezer/refrigerator doors slightly open overnight, could cause your evaporator (coils) to freeze/ice up. cases like this, unplug/disconnect your refrigerator, remove produce, clean and let it defrost, for an hour, make sure all ice melted. plug or reconnect your refrigerator let it work/ run empty for another hour, then put back your produce. sure it will work perfect for the next 3-4 days. (2) next type of defrost problem could be faulty defrost heater, defrost thermostat, you will have to open back panel on freezer side to check. check your defrost heaters, defrost thermostat and defrost timer, it's better to change defrost timer and defrost thermostat together, or change faulty ones independently. but before you change any parts, clean and defrost refrigerator first, could just be regular openings, hot days, etc. if after 3-4 days it started to ice up, then check following parts. defrost heater. defrost thermostat and defrost timer, let me know if icing occurs after 3-4 days then we can check those parts i suggested. remember to always disconnect/unplug your refrigerator, before attempting any repairs. good luck
Aug 21, 2009 | Maytag MSD2656G Side by Side Refrigerator
Frig side not working on Maytag MZD2766GEW
freezer not defrosting. probably adaptive defrost board in fridge.
take panel off freezer (inside, back panel). if all frozen, can defrost with blow dryer. best to remove fridge control panel (inside, top of fidge). access adaptive defrost board, jump test to f1 (i think) next to test. this should initialize defrost mode. buy new board.
May 23, 2009 | Maytag MZD2766GES Side by Side...
Runs and freezes than goes into defrost mode and never goes back to freezeing
HI .thanks for the question. I think your problem is with the thermostat. It gets cold shuts off , and does not come back on . I would replace the thermostat. thanks the appliance doc. please rate my answer.
Sep 28, 2008 | GE GTS22WCP Top Freezer Refrigerator
GE used refrigerator....
I would try defrosting first. If no difference, or worse then you may have a refrigerant leak. You could always try setting back to the original setting. Hope this helps.
Aug 02, 2007 | GE Freezer  14.8 Cu. Ft. Manual...
Paragon 4001-0G Defrost Timer Logo
134 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
