I have been searching the machine for something which could be rubbing against the belt to cause it to fray and break as often as it does. So far, I haven't found anything. I have heard that the belts, called ribbon belts, are terrible! I find that the belts break faster when I use the hose. I haven't found a way to make a belt last longer.
How long hace you had your vacuum? THe belts on this vacuum are actually supposed to last a really long time. If the belts brake faster when your using the hose that impies your clutch which tightens and loosens your belt to keep the brush from spinning while the vacuum is upright couild be malfuntioning. If you post your serial number i can tell you if your still under manufacturers warranty.
my belt doesn't engage when I try to sweep but when it's in an upright position the roller is...
(More)
my belt doesn't engage when I try to sweep but when it's in an upright position the roller is moving...
I have a Eureka Smartvac 4870 which has very weak suction both on the floor and with the hose. There...
(More)
I have a Eureka Smartvac 4870 which has very weak suction both on the floor and with the hose. There is a new bag, new belt. There are no blockages or dirty filters. It also no longer "drives itself" (when it worked correctly, it would move itself forward). Do you know what's wrong? Thanks!
replacing motor in 4870, replacement motor slightly different, need wiring diagram......replacement...
(More)
replacing motor in 4870, replacement motor slightly different, need wiring diagram......replacement motor #62430
brush does not turn and culprit seems to be that the barefloor /carpet switch will not stay in the...
(More)
brush does not turn and culprit seems to be that the barefloor /carpet switch will not stay in the carpet position.
