Question about Pantech Matrix Cell Phone
Its a metro and it purple
When i plug in the charger it wont charge and i have to keep moving it around for it to charge.
    President:
  • 1,952 Answers
Check the charger for output voltage.
2. Clean the charger contacts in the phone with a q-tip and a little rubbing alcohol.
3.Check the cord on your charger for cuts, breaks etc.
4. If it's a car charger, check the outlet in the car for voltage, check the cord's fuse in the handle,
5. Check the battery-to-phone contact connections for cleanliness, tarnish,
6. replace battery with new.
Let me know how you do...
Posted on Jul 03, 2009
My kocaso tab wont turn on whille charging
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Dec 28, 2014 | Kocaso Sx9700
My phone keeps saying it's charging when its not even plugged in. But although it says its charging the percent of the battery goes down real quick what can it be. And if I connect the phone to the...
check the input and spray compressed air to clean.. do not blow into it cause moisture is expelled when blowing. turn of device and remove battery. spray again. wait 15 minutes. place battery back in power on
Oct 04, 2017 | Cell Phones
Once i plug in my charger its wont charge!
Turn it off, & keep it off for a while. It's happened to me as well. Turn it back on & plug the charger in.
Dec 16, 2011 | Sanyo SCP-2700 Cell Phone
When i plug my charger in i have to move it around for it to start charging and if i move my phone it quits charging its not the chargers i have tired im thinking it my phone. what do i do?
The charging socket on you phone needs to be resoldered, OR the plug on the charging adapter is faulty and needs to be replaced.
To determine which is faulty, use a different charger and plug it into your phone and move the charging plug to see if the it quits charging. If it quits charging then the charging socket on the phone needs fixing (re-soldering).
May 07, 2011 | Cell Phones
My cell phone charger is plugged in and not charging i can move the phone around and it will start charging but then will stop again if it moves again. Ive tried other chargers and they work
Hi,are you saying that it charges well when you use another charger? it is possible then that you will have to get another charger..but if it behave the same way with other charger, it means the charging port is faulty...cheers
Jul 10, 2010 | Cell Phones
My samsung metro pcs phone wont hold a charge and I have a hard time getting the charger to work. No matter what charger I use I cant get it to work. If I get lucky the charger will work. What do I do?
there i no need troubling yourself further, the problem with your phone is the charging port, the charging port of your phone is bad that is why, your phone battery cannot hold charge.
Change the charging port of your phone and your phone will charge and hold charge.
Regards.
Apr 26, 2010 | Cell Phones
Batteries won't charge w/ on board charger-+
sounds like blown fuse which is at rear of chair. may be underneath rear cover. this fuse wont keep the chair from working, however, it will keep the charging from working.
May 29, 2009 | Invacare Supply Group Invacare Pronto M91...
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
My phone wont charge
To fix it , the phone must be taken apart, and a new charger socket must be soldered into the internal board.
This is a precision job and must be done by a technician.
I suggest going to a phone repair shop and asking a quote for the repair.
Sep 13, 2008 | Cell Phones
Pantech Matrix  Cell Phone Logo
96 people viewed this question
Top Pantech Cell Phones Experts
Abdul Mannan
Abdul Mannan
Jax Planet
Jax Planet
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
