No power, tried fuses ok
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
i fixed this exactly as previous posted solutions, however a couple of points.
a) recordable CDs work if you don't have a DVD burner.
b) I didn't have a CD burner that would do an "image burn", I downloaded a free copy of "Express Burn" and that worked fine. The disk needs to be "finalised" or "fixated", it should do this automatically, or it may be a tick box selection.
c) I got a "No DWLD 09" when I put the disk into the player. I found this was an incompatibility with the CD-R (Maxwell) I was using. I changed to JVC and it worked fine.
SOURCE: My lg blue ray dvd player wont play regular dvd's
sounds like a bad optic or a software issue
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
SOURCE: blue ray player wont play a new disk says it needs
Software updates have to be done on bluray players whenever the technology in bluray discs themselve is changed. If you call the number for 20th century fox on the back of the bluray a representative there will explain to you what has changed technologically in this bluray that has caused there to be software updates for all of the bluray players. I believe LG can send you a disc so that you can update your player. Give them a call. The bluray players are all manufactured and shipped to the stores. In the meantime if an update is needed and its sitting on the shelf at the store until you buy it, even if you've just bought it an hour ago it will still need to be updated. The stores do not unbox the blu ray players and update them for you. However the Geek squad will update bluray players for customers for a fee.
SOURCE: my sony blue ray player
I'm having the same problem. My BDP-S350 Blu-Ray Player used to play blu-ray DVD's but suddenly is unable to. Regular DVD's I can play. Please help!
On blu ray remote control hold down TV Power+01 at the
same time. If the TV turns off the controller is programmed. If not, try TV Power+02,
+03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
