Question about Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592
Hi the basket/strainer gets empty all the time and I'm scared that the pump will break any minute
  • 22 Answers
Check the water level in pool to make sure pump isnt running dry.check the o ring where the pump lid is and lubricate.check that the valves to the front of pump is in the propper location.
Posted on Jul 10, 2009
How do I get water in the strainer housing basket?
guess you need to add some water they do not self fill usually .
May 20, 2015 | Hayward Pool Products Hayward Power Flo LX...
C48k2n143b1
possible leak from pump motor and pump housing its losing prime in basket less hassle to replace whole pump if leaking its ruining bearings in motor
Feb 15, 2018 | Pool & Spa
Not pumping strong. Filter pressure gauge is going low.
Could be air entering the pump on the suction side - dead giveaway is a stream of bubbles entering the pool, possible causes are damage/faulty pipe joint, leak at strainer basket - is the o-ring clean and in place, is the lid craked? Other possibility is leaves etc caught in the impeller caused by damaged or missing strainer basket.
Jan 23, 2011 | Pentair 011515 WhisperFlo FullRated Energy...
Both of the Pegasus baskets in my sink have come apart. I put them back together and they come apart again. I would like to purchase new baskets, but can only find the entire drain assembly, which I do...
I know what you mean I had similar problems with my sink strainers, unfortunately is you want to get a good working basket you have to buy the whole drain assembly. You can get some cheap ones at a home store but they will only break again and probably won't match up. What I recommend is swapping out your drains with a drain brand that won't break again like Kohler, Moen, or Elkay. All you need to install a new drain is the new drains, a drain nut removal tool and some plumbers putty. Take the old drain out clean around the whole and install the new one with a ring of plumbers putty around the hole.
Jul 09, 2010 | Pegasus Technologies Pegasus Kitchen Sink...
My Barista Saeco is 4 yrs.old. Pump works good in the steam cycle but bogs down in the brew cycle. Today the pump almost stopped completely. What's up?
Try cleaning your portafilter. Put a pinch of automatic dishwashing detergent in the portafilter basket only. Brew until you get suds comming out then stop for 1 minute. Repeat 5-10 times, stoping for the minute each time, until you get white foam. Then rinse basket and brew empty for a complete tank. Then try brewing again with coffee.
Dec 31, 2009 | Starbucks Barista Utopia
What is better durability for the materials in a kitchen basket strainer, brass or brass PVC?
PVC is easier to break, but takes hard or high iron water better.
Brass seems to last longer overall in my experience
Oct 03, 2009 | Mountain Plumbing Mountain Basket Strainer...
What is a ld error code? It will not spin when it is supposed to spin fast. This is the error code that comes up.
LD is the error when it takes longer than 5 minutes to drain the water out and reset the sensor. Press pause/cancel twice to clear. The washer will begin a slow spin, and when the motor allows, increase the spin speed towards the spin speed selected. Depending on the model, it will make several attempts, each time pulling water off of the load at the slower speed. If it cannot "get permission" to increase to it's selected speed within the allotted tome, it ends the cycle and the error code "LD" is displayed. Usually two common things can contribute to the DL alarm. One is the strainer, and the other is the drain line. The strainer is in line between the drum and the pump. On a front loader, it is behind the kick panel below the front main panel. It is connected to the drum with a rubber hose and strains the water going to the pump. Clean the strainer, and, while it is open, look inti the pump cavity. Remove any debris that you find there. Reassemble the strainer.
Anything that gets by the strainer and pump will eventually pass through the drain line and on out through the house drain. Empty the drain hose into a bucket to help displace any sediment and debris in the line. If possible, run an empty cycle with the drain hose pointed outside.
Best regards, --W/D--
Aug 13, 2009 | Kenmore Washing Machines
I have Hayward earth filter for the pool along with a Pentair Mini Max 100 pool heater - first time starting both for the season and the filter motor is making a straining noise. For the few minutes its...
make sure all vents are clean check to see if there is anything stuck in impeller with pump off take straner basket out look at opening going back to filter is water filling the strainer basket
Jun 17, 2009 | Hayward 1.5 Hp Northstar High Performance...
Maintenance Question
If you live in a windy area or have debris getting into your pool then you should check the pump basket at least once per week or after you have vaced the pool.
Aug 27, 2008 | Brasstech 130-26 Junior Basket Strainer...
How to Clean Pump Strainer basket
Turn the swimming pool pump off and wait for the water to drain from the strainer basket. You want to make sure that the pump is completely off before you proceed. Remove the screws or any items securing the lid of the strainer basket. Open the lid and pull out the strainer basket. Vacuum the strainer basket or scoop out any debris. You may want to run clear water through the basket to ensure you removed all debris. Feel toward the impeller and remove any clogs or obstructions preventing the impeller from working properly. Check the o-ring under the cover of the pump strainer housing. You may need to use a silicon lubricant to ensure a water-tight seal. Put the strainer basket back into the pump strainer housing and pour some water into the basket. Replace the lid and secure it in place. Turn the swimming pool pump on and check for proper pressure. If your pressure doesn't register, you may need to troubleshoot to find the problem.
Aug 27, 2008 | Belle Foret Accessories NBBS2-TB Tumbled...
Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592 Logo
120 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
