Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
My dyson dc07 is does not have the suction it used to. what should I do?
  • 33 Answers
You can't always wash that to get it sucking again, this might help:
http://www.fixya.com/support/t2827418-very_little_suction_in_hose_no_tears_in
Posted on Jan 26, 2010
    Sniper:
  • 83 Answers
There are a couple of things you can do and it depends on whether you don't have suction from both the wand and the bottom of the
machine or just from one side:
1) First check the suction of the machine to ensure that the motor is still good - remove the canister and look for the two
openings/holes on the spine/frame of the machine - put your hand in front of the hole on the LEFT (higher than the hole on the right)
- if there is suction, continue the troubleshoot instructions, if there is no suction your motor may be damaged - call the Dyson
Helpline, they'll set you up with a repair with the closest authorized dealer in your area.
2) Check for blockages from the bottom of the machine. Remove the:
(i) U-Bend (stand behind the machine and look next to the right-hand-side wheel, it's attached with a rectangular clip next to the
long gray hose - push the clip and pull the U-Bend off, make sure its clear - if there's a blockage remove it and continue with the
blockage check to ensure that the entire machine is clear)
(ii) AI Valve (stand behind the machine and look above the right-hand side wheel, it's attached with two buttons on either side of the
AI Pipe/Valve - push the two buttons and pull the pipe up and off and make sure there is clear - if there's a blockage remove it and
continue with the blockage check to ensure that the entire machine is clear)
(iii) Refit the internal hose on the bottom of the machine between the wheels and make sure it isn't torn and has no holes in it and
that there is nothing clogged inside it - to refit the hose: Pull it off where it sits next to the wheel first - make sure that the
gray piece of rubber is still on the hose (if it isn't, pull the gray piece of rubber off the hole and reconnect it to the hose by
twisting it back on) - next, twist the hose off where it connects to the brushbar - inspect the hose and make sure you don't have any
holes in it - put it back on by twisting it onto the side of the brushbar first - then line the gray piece of plastic end up with the
hole next to the wheel and push and twist it back over the hole. Bring the machine back upright and test it
3) Check for blockages in the wand. Remove the:
(ii) Wand - take the wand off the back of the machine - put one hand on the wand handle and one hand on the gray hose - pull the
handle and push the gray hose down, you'll see a metal rod being exposed, push the hose until it clicks into place - press the
half-moon shape button with a picture of a lock on it (found on the solid gray plastic end of the flexible hose) and separate the wand
competely - point the wand into the air or at a source of light (please don't point it at the sun) and look through the metal rod part
- the handle is bent but you should still see some light coming through the other end - if you don't, there is a blockage in the wand
- use a long object like a stick or a metal hanger to remove the blockage
(iii) Hose - no need to remove it - just stretch it out and make sure that there are no dark spots in the hose (those would be
blockages) - you can also through the top of the hose - if you don't see the ground at the bottom there is a blockage in the hose
4) If no blockages are found on the machine at all:
(i) wash the filter in cold water and leave it out to dry for at least 24 hours
(ii) blow out the cyclone from the bottom (open the door on the bin door - you can now look into the cyclone) - blow it out with an
air compressor or a leaf blower
(iii) Wipe all the small holes off on the cyclone with a dryer sheet
When the filter is dry, test the suction again. If there still is no suction on the machine, call the Dyson Helpline, they'll set you
Posted on Jul 30, 2009
  • DysonFan Jul 30, 2009
    Novelist:
  • 171 Answers
Hi there SmartAlec from nelsonvacuums.com.au here. First thing to try is if it improves with your washable filter removed then replace your washable filter buy here . If the filter is not he cause then it is likely a blockage in the radix assembly. Post another question if you think this may be the cause. I will need a bit of time to answer that one though (its pretty tough to clear).
Happy Vacuuming! :)
Posted on Aug 26, 2009
    Problem Solver:
  • 5 Answers
I've got a dc 04 and it lost a lot of suction over time. First I made sure nothing was stuck in any of the pipe work. Then I checked the HEPA filter (the big circular sponge filter at the top of the cylinder) it was filthy. Wash it with water to get out all the dust then dry by a radiator for a couple of hours before reinserting. If you're in a real hurry just do the vacuuming without it in - it's just a bit of foam to stop very fine particles from escaping.
Posted on Aug 12, 2009
4 Suggested Answers
SOURCE: Dyson Dc07
I had the same issue and solved it easily.My experience is the same as the March 6th response/ When you push your foot onto the base and then recline the handle, use your toe to gently push the very front of the base down closer to the carpet. This creates a much stronger seal and suction and picks up every bit of dirt easily. If i do not do this extra step the suction is much much less. I tried an experiment with sand that I poured onto my carpet. Initially, I went over the sand 4 times and the dyson 07 would only pick up 50 percent of the sand. I then poured more sand onto the carpet, and this time pushed the front lip down so it was contacting the carpet. This time only two passes were needed to completely **** up all the sand. Not sure why this is not in the manual but it really works. Good Luck!
Posted on Jun 29, 2008
SOURCE: rotating brush will not turn on my Dyson DC07
Yes I had the same problem on my animal Dysom. There is a button on the top of the dysom that turns the cacuum on. Right beside that button is another one that turns on and off the brush!!! Good luck!!! I accidently one day bumped that button and couldn't get my brush to work but after troubleshooting it, that was my solution.
Posted on Jan 24, 2009
  • 5 Answers
SOURCE: dyson dc07 yellow/blue no suction at base
Sounds like you've **** up something which is obstructing the suction from the brush bar. There's a little section of curved grey pipe near the base which carries the dirt from the head up the vertical pipe at the back. This section can be removed, check there is nothing jammed in there, paper etc.
My dyson crawls up to me - hose is not relaxed
Hi Colleen,
Due to your DC07's very powerful suction, it's normal to experience a certain amount of resistance when using the hose. But if the hose seems to be pulling back excessively, this indicates you may have a blockage somewhere in the hose, wand or accessories. To check for this, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc07/dc07-standard/my-machine-is-not-working/machine-not-sucking-picking-up-as-well-as-usual/how-to-wash-filters/wand-suction
I hope this information is useful. If you would like some further advice from our experts, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Support
www.dyson.com
Aug 15, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson seems to have lost its suction therefore is not picking up anything yet i have found that when my dyson is standing upright it has a little more suction but nothing like how it use to work. This...
Sorry to hear you're having a problem with your DC07. You should be able to resolve the issue by following these simple steps: http://www.dyson.co.uk/support/help.asp?article=1940&product=DC07-SY
If you're still experiencing difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
May 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction! cleaned it, and still no suction!!
It's almost certainly a clog. Here's the Dyson page which shows you how to remove a clog from 8 possible places.
http://www.dyson.com/support/help.asp?article=528&product=DC07-SY-HEPA_US
If you found this useful, please vote.
Feb 24, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I just bought a used Dyson DC07. Works good but
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
Kind regards
Darran
Jan 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 bagless - upright mode v poor suction, wand mode ok
From your description of the problem, it sounds as though the bleed valve is activating which only happens when there is a blockage.
We would recommend following the full blockage through as outlined in your user guide or in the Support section on our website at www.dyson.com.
Kind regards
Darran
Jan 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 shuts down after 5-10 minutes of use and horrible suction!
I have had this problem on two dysons and have solved it by replacing the so called lifetime pre-filter. The problem is not the washable blue sponge but the material gauze filter in the plastic surround.
To see if this is your problem try removing the whole filter (i.e. the filter with the blue sponge inside - you need to remove both bits not just the sponge).
If you do a quick vacuum test for a few minutes then see what effect this has on the suction.
If you need a new part try somewhere like here (you'll need to chose for the right model) : http://www.espares.co.uk/part/dyson/dc07/p/1086/716/6/420625/875479/lifetime-pre-motor-dyson-.html
As I say this has fixed both of mine.
Oct 27, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Suction
Hi.
If you have checked & cleaned all filters & its still no good go to this site http://dysonmanuals.llc.nu/index.htm
Then contact page you require DYSON DISC (1) DC07 NO/POOR SUCTION O/HEATING.
This will sort out your problem.
May 06, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 loss of suction
Hi.
Check brush roller is spinning when vacuuming.
Check short clear hose under machine for rips & blockages.
Chris..
Jan 05, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
626 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
