Question about Whirlpool Washing Machines
I keep getting an F6 code on our Whirlpool Duet front load GHW model washing machine. We have had a guy come out and he unplugged wiring on motor and board and replugged and watched it go through cycles just fine. After he left we did several loads then again we get an F6 code. Disabled again. It will start a cycle and then about 3-4 minutes into cycle after water starts on clothes it will give an F6 code. Please let me know if this is something I can fix myself or what could be causing this code. Thanks, Glenn
SOURCE: The duet washing machine fills up with water in between loads. What is Causing This?
Dont want to endorse a commercial site, but you can by a generic part for a bit over $10 for this problem, so do some seraching for a reasonable site (other sites are charging 40-50 dollars for a fill valve.
Posted on Aug 09, 2007
jsrock516
  • 5911 Answers
SOURCE: button start locked my clothes locked inside washer duet whirlpool ghw-9200lq
If you suspect you have a defective door latch, you should be getting an error code of "Fdl" displayed on the console as well. This may just be a matter of a malfunction where the latch became jammed. You can still get your clothes out of the washer by removing the lower panel under the door. There are 3 torx type screws under the bottom edge of the panel. After removing the panel, place your hand inside the washer behind the front casing where the door latch assembly is. Try to locate a plastic tab at the very bottom of the door latch and pull straight down. This is a manual door release and the door will open, allowing you to retrieve your clothes. With the door opened, try closing it again. Select a wash cycle and push start. Listen to see if you can hear the latch lock. Push PAUSE/CANCEL to stop the cycle and listen to hear if the latch unlocks when the cycle stops. If you definitely have a defective door latch, follow these steps to replace it:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub. This requires more steps, which means removing more parts, which means more time (plus patience).
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom.
Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in. At the control panel select:
DRAIN SPIN
NO SPIN
and under OPTIONS press any key (has the be the same key) 4 times.
This places the washer into diagnostics mode. "C00" will be displayed on the screen and you should hear a distinctive "click" of the door latch. If diagnostics passes, the washer will run through a series of tests, tumble, drain and then spin. When completed, the unit will make an audible "beep" and the CLEAN light will be lit.
You can stop this process at any time by press the PAUSE/CANCEL button. Good luck to you and let me know if you have any further questions.
Posted on Feb 10, 2008
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
  • 1294 Answers
SOURCE: Whirlpool Duet Error code F 32
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. All you guys are going to rate me....................
Posted on Jun 16, 2008
  • 1028 Answers
SOURCE: whirlpool duet washer (ghw 9150
find button with lock emblem beside it hold down 3-5 secs
Posted on Oct 05, 2008
What does and F6 error code mean on a whirlpool duette front loading washing machine mean and how do I fix it?
Error code F06 means Drive motor tachometer error.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
1/ Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
2/ Check the Drive Motor
3/ Check the MCU
4/ Check the Wire Harness
Replace failed component or contact an authorized repair agent.
Oct 15, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Ho do I reset the whirlpool error codes f6
F06 Drive motor tachometer error The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Whirlpool Duet error f6 Google Search
Sep 06, 2014 | Whirlpool Duet WFW9151YW 27" Front-Load...
I had whirlpool duet wfw94hex0 error code f6 -e2
If it's the same as a UK version, F6 is a motor speed sense fault
Dec 23, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Keeps flashing F6,wont do anything else
F-06 Drive motor Tachometer error
Possible causes/procedure:
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
The rest of the codes are HERE
Aug 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is an F6 on my duet washer? I already
three things.... could be the motor, could also be the MCU (  motor control unit ), could be the wiring harness .  check the wiring harness between the speed sensor at the motor and the MCU.  i have run into all of those being bad on different machines.
Aug 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet model # ghw 9400 lo.door locking problem.
One hour service plus $40 part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 14, 2010 | Whirlpool GHW9400 Front Load Washer
I keep getting code F6 what can we do?
F06: problem with motor...could be the motor board (lower) or the motor....but usualy it is the board that is defective....
Jul 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer duet
F/06
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
Nov 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
201 people viewed this question
Dan Webster
Dan Webster
Sal De
