Question about Microsoft Xbox Console
Sound issues with xbox live
I am trying to get the audio to work on xbox live for my original xbox but it doesn't come on? Not with regular speakers or headset. I tried switching out the headset and it didn't work. I reset the settings for mixed speakers and I can't hear anyone talking?!! Its real frustrating. Can anyone help?
  • 152 Answers
Maybe it has something to do with your controller. Try a different controller.
Posted on Dec 21, 2007
My computer doesn't detect my speakers, I do have windows 8
Do you have the AC adapter plugged into a live outlet and have you turned on the speakers? Make sure that the speaker signal cable is plugged into the correct port on your computer (the lime green port on a desktop). Check that the correct audio driver is installed for your computer. (With Windows 8, use the Device Manager to check. From the Start Screen, type in Device Manager. Click on Settings and then select Device Manager. Alternatively, Windows key+C on the desktop. Select Settings and then Control Panel. You can find the Device Manager under System and Security or Hardware and Sound.) Scroll down to the Audio devices. Expand the section and look for a red triangle with an X or a yellow triangle with an exclamation point. Try updating the driver (check with the manufacturer of your computer for the latest driver). Even if you don't see the error triangle, try reinstalling the latest driver.
Next check if the speakers work on another computer. If they don't work, the audio cable may be damaged. Try a different set of computer speakers on your computer.
If other known good speakers do not work and the correct audio drivers have been installed, check the audio output devices. Go to the Control Panel > Hardware and Sound page (as described above). Choose Manage Audio Devices. Check if the HDMI port is set as the default audio device. Disable it for a bit (right click on the device) . Sometimes when a new video card is installed, the audio device defaults to this port. This messes up the drivers for the regular audio.) Reboot the computer and then try reinstalling the audio driver. Reboot again.
If it still fails, there is probably something wrong with the audio device hardware. If you are using an add-on sound card, try disabling it and using the motherboard audio device. (A number of add-on sound cards didn't work well with Win7 or Win8. The on-board audio drivers worked better.) If you are using the motherboard audio on a desktop, try an add-on sound card. (Check for Windows 8 compatibility (drivers) before selecting any card.)
I hope this helps.
May 29, 2013 | Kinyo PA-1158 2.0 Amplified Speaker System
My xbox is banned from xbox live
If you made a new account for yourself and it wont work, try to delete the old ones. If that doesn't work, contact customer support and see if they can tell why it's banned and if you can have it removed as you are not the original owner.
Sep 16, 2012 | Microsoft Xbox 360 Console
No sound. Tried disconnecting/reconnecting all input/output HDMI cables. Only computer is connected via RCAs (for sound only). No sound at all. Audio works on HDTV, which is going from cable box,...
Did the speaker relays light up ? and did you hear the third speaker relays ON clicking sound? If both no, DSP problem. If both yes, DIR problem. If the speaker relays lit up but NO speaker relay clicking sound, check relay driver +24V power supply.
Sep 17, 2017 | Yamaha RXV467 Receiver
Rear right speaker doesn't work, no matter what we tried. We switched the speaker and cables with one of the others, but just that position (surround right) doesn't work.
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Sep 09, 2011 | Spherex Xbox 5.1 Surround Sound System...
Troubleshooting Kinect audio problems Page ContentBelow is a list of common Kinect audio problems along with suggested solutions.
If you are experiencing...
Try this...
An echo
  • Turn off digital effects on your audio receiver. Digital effects include things such as reverb, compression, and synthesized surround sound modes.
  • If you are using a TV and an audio receiver at the same, turn off the volume on the TV.
  • Use the Kinect Audio Tuner.
  • If you are hearing an echo during Xbox LIVE gameplay but not while you are playing offline, the problem might be with another player's Kinect sensor. Ask the other player to run the Kinect Audio Tuner.
No sound from one or more speakers
  • Make sure that the Xbox 360 A/V cable is properly connected to your audio system.
  • Make sure that all speakers are connected to your audio system.
  • If your audio system has speaker switches, make sure that the switches are on.
  • If your audio system has a receiver mode, make sure that the setting matches the number of speakers connected. For example, If you have Use this mode Two speakers Stereo Five speakers and a subwoofer 5:1 Seven speakers and a subwoofer 7:1
Kinect voice commands are not working
Run the Kinect Audio Tuner
Your friends cannot hear you during chat
Make sure that the chat microphone on the Kinect sensor is on. Here's how:
  1. On your console, go to My Xbox, and then select System Settings.
  2. Select Kinect Settings.
  3. Select Chat Microphone.
  4. Select On.
Dec 11, 2010 | Microsoft Xbox 360 Console
Can't get XBOX 360 to have audio through surround sound speaker
Make sure that you have the RC Cables (red and white) plugged into the audio ports that coincides with the component video inputs. If that wont work then try plugging the audio and video cables into the inputs for the satellite, since that works. That way you can isolate the issue. If it still wont work try using the XBOX 360 HDMI cable. That has both audio and video.
Jan 03, 2009 | Sony BRAVIA DAV-HDX267W Theater System...
First you have to activate the HDMI audio option in your Sony suround system options so as to activate it. Please try this and then tell me what happens.
Nov 25, 2008 | Microsoft Xbox 360 Elite Console
Audio Breaks
Hello vatsala,
Try downloading and installing the latest sound drive available for your motherboard. Here is the link.
If that doesn’t work, try using another set of speakers to make sure it’s not your speakers that are bad and if that doesn't work, you may have a bad sound card and will need to put in new sound card.
Agent Xiong
Apr 16, 2008 | Creative Labs Sound Blaster Live! 5.1...
HTS-GS1 Surround Sound System cannot be utilized for tv.
Check Your TV audio setup,many TV makers out there would like you to turn off the tv speakers in order to use the external speakers.
Feb 03, 2008 | Pioneer HTS-GS1 Theater System
Microsoft Xbox Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
