Samsung galaxy s2 I would like to unlock it
You can get the unlock code for your Samsung Galaxy S2 phone from ClassicUnlocking.com and unlock your phone from Network lock easily.
SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
SOURCE: Need to reset samsung galaxy s2 phone. Can't
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode"
If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
SOURCE: Cannot charge Samsung Galaxy S2
first, test th charger with another phone to confirm if its working or not.
If the rempte is working, then it means the charging port of your phone is defective and needs to be replaced.
Regards.
Testimonial: "Thanks!"
SOURCE: USER MANUAL FOR A SAMSUNG GALAXY S2
http://www.manualusersguide.com/samsung-galaxy-s2-user-guide-manual-pdf-download.html
Hello here is the link where you can download the user manual for your phone. I have downloaded it for you so you dont have to do it but for some reason i cant attached it in here. So instead i give you the link. It is easy jsut go in this site and at the very bottom you will see download samsung user manual pdf. .just click it and you will be downloading the pdf file in no time..
Hope this can help you..have a nice day..
SOURCE: free unlocking codes for samsung galaxy s2
Free codes does not work sometimes..So better you purchase the unlocking service from your network provider or you may get it from online providers like http://www.prounlocking.com/ .They will help you to unlock your mobile easily.
1 - Switch ON your Samsung Galaxy S2 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung Galaxy S2 is locked to.
CODE: Its the unique Unlock Code for your Samsung Galaxy S2.
