My rca projection screen is about 6 years old and the picture seems very dark and red. What can I do to fix this?
    Sergeant:
  • 285 Answers
You will need a new bulb. google rca (model) bulb, and buy it.
Posted on Jul 03, 2009
I'm trying to improve the picture- seems to be TOO DARK- tv is 10 yr old ser3 935351541- ihave tried color adj etc
Rca Screen Control These sets have screen control adjustment usually located behind the speaker grill(pops off -velcro or press tabs) and convergence front board. There are 6 contols on a black molded assembly about 31/2"x21/2" square. adjust only the top controls marked "Screen R G B" the bottom ones are focus
Method:
-turn on set and let warm up for 30 min at least
-switch tv to blank unused video input channel
-adjust each control in turn until you see the picture glow (with the corresponding color) and slightly back off the control - repeat for each color - this will increase screen brightness and ballance your color
Hope this helped.
Oct 18, 2009 | RCA P52945 52" Rear Projection Television
Dark picture
are you using the s-video input
Jan 10, 2009 | RCA P52926 52" Rear Projection Television
Rca 62" PROJECTION FLATSCREEN - COLOR PROBLEM/FLICKERING SCREEN
Sounds like the red picture tube could be shorting internally which would cause the "all red" condition. In which case you'd have to replace the red tube. Are there horizontal (slightly slanted) lines through the picture as well when this is happening and a very very bright screen? If so it's most likely the tube.
Oct 06, 2008 | RCA F36645 TV
My RCA is a big screen 52 " is about 7 years old
yes this problem can be fixed but the price may scare you!
Sep 09, 2008 | RCA HD52W59 HDTV Projection Television
Faint red lines in a curved arch like pattern
Is there a cheaper solution? $600 sounds like you just throw it away to me...
Aug 02, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Small picture with lines
check these two resister also R19702= 750k, R19703= 750k
Dec 20, 2007 | RCA P46921 46" Rear Projection Television
RCA hd50lpw42yx2
If you have the extended warranty, use it immediately. This happened with ours after our 1 year warranty expired and found out it would cost us over $1000 to have it fixed. We've read that RCA used faulty glue that can't withstand the heat inside, causing a mirror to slowly slip over time. Our dark shadow keeps growing and growing.
RCA should have recalled this to fix it for everyone.
Nov 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV D40W20: Turning it ON
There seems to be problem withe picture screen.Drop into the nearest service center and it will be fixed.Its not a problem at all.. To find the nearest service center in your area click on the link below.. http://direct.where2getit.com/cwc/apps/w2gi.php?client=rcathomson&template=searchretail_new
Oct 08, 2007 | RCA Scenium D40W20 40" Rear Projection...
Hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Jan 22, 2007 | Hitachi 50V710 50" Rear Projection...
Help
if the tv has never been service before you could have dust on the 3 tubes,this will decrease the brightness to the screen. try taking the front or back off & see if you can see the top of the picture tubes. remember to unplug the tv & to clean spray the cleaner on the colth , then clean the tup of the tube. never spary on the tube itself. hope this works for you. to remove the screens remove the front grill, then remove the screws @! the bottom of the screen & if i remember right the top just sits on a lip, so gently try to lift the screen up.careful, these screens are expensive & you will have 2 or 3 of them. some of them are really easy to scratch.
Oct 22, 2006 | RCA P46924 46" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
