Question about Sony Cyber-shot DSC-W70 Digital Camera
Flash setting camera shows note : ! flash settings cannot be changed and takes the pictures without flash
    Sergeant:
  • 246 Answers
On some shooting modes, you can not set the flash on. Try to change to other shooting modes, or just ATUO.
Posted on Jul 03, 2009
When i take pictures they show with a pink color? i reset the camera to factory settings but still same pink pics advise?
This FE-340 Olympus is a great camera. Lots of features and usually great results
  • Indoor pictures with flash set on auto WB (white balance) should not be a problem
  • Indoor pictures without flash requires setting the WB to match the light source in the room (incandescent, florescent etc) Outdoor pictures WB on auto generally not a problem
For more help Include a photo with the metadata of the photo from the image data file
Dec 02, 2015 | Olympus FE-340 Digital Camera
Display screen does not show picture
Could be your camera is still working, but some settings are messed up?
You could have turned off the display. In the menu with IMAGE DISP. Is used to save battery power.
Then try making pictures in the mode automatic. Because if you switched to scene like bright sunlight or snow your pictures can be very dark.
Jan 16, 2014 | FUJIFILM Cameras
Shutting off flash
Yes, but not in the Auto mode, where the camera decides whether or not it needs the flash. Switch to the P mode, which works like Auto except you have control over the flash, exposure, and other factors. See pages 26 and 42 of this manual.
Apr 12, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
I have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing...
i have a sony cybershot DSC-W210 and just recently the flash wont work when its on any mode to take a picture it has the flash symbol on the screen flashing and the code E:91:01 underneath also flashing its takin pictures as normal just without the flash it wont let me change the settings of the flash at all
Jun 14, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
How to switch off the flash in Canon Power Shot A510
in the take picture mode, press the button that has an image of the flash on it (the top of the circle) on the right, and keep pressing it until you've selected the image that shows the flash crossed out.
Mar 27, 2010 | Canon PowerShot A510 Digital Camera
Shutter slow, pictures blur if not on solid object. Exposures OK.
This is a common problem if you are taking pictures in low light with out using the flash.
I suggest to set all settings in your menus to factory settings. Then set them the way you want. This may change some settings.
Always either have the camera on a solid surface or use a tripod when you take slow shutter pictures without the flash.
Oct 19, 2009 | DXG Technology DXG-503 Digital Camera
Screen goes dark between pictures
Probably a power saving - OR- a timer setting.You should be able to change the setting easily.
Mar 18, 2009 | Canon Powershot SX110 IS Digital Camera...
No flash in "P" mode
In all of modes you can use "up" key to toggle between "always on", "auto"  and "off" mode for flash. (in some mode there is only auto and off.) also the flash light icon on top right of screen shows th status of flash. I hope this helps...
Aug 02, 2008 | Canon PowerShot A640 Digital Camera
Red light continually flashes, and won't take picture
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Mar 05, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Outdoor pictures reveal white on LCD screen
The sensor for the auto-ISO may be working incorrectly. Try changing the ISO manually for different light modes. You can also try to change the white balance of the LCD. -Setting the white balance: 1. Set the camera to still image mode 2. Press the "Set" button 3. "White Balance" should be the current selection 4. Press the "Flower" button or "Flash" button to move through the available options for white balance 5. Press "Set" again when change appropriately - Setting the ISO: The higher the ISO value, the less light the camera needs to make an exposure, allowing the same exposure to be achieved with higher shutter speeds or smaller apertures. In a digital camera, higher ISO value allows higher shutter speed, at the expense of mottled or grain appearing in the final picture. 1. Set the camera to Still Image mode. 2. Press the "Set" button. 3. Press the "scn" or "timer" button to select ?ISO?. 4. Press the "Flower" or "Flash" button to select the desired setting. 5. Press the "set" button to select. 50/100/200 In the same lighting condition, the higher the ISO value is, the faster the shutter speed will be. I hope this helps.
Aug 06, 2007 | Polaroid i832 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
80 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
