Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Ic replacement I have a JVC av48wp74 with a problem with the red convergence.  I pulled out the board and the ics on the board are ic801 and ic803.  the other posts talk about ic804 and ic805, am i looking at the right ic and if so which one is for the red? thank you
    Genius:
  • 1,694 Answers
Replace both IC's or you will re-visit later! STK-392-110 X 2....
Posted on Nov 26, 2007
I have a jvc model av-65wp74. my green convergnece wont align at all
Convergence ICs and resistors need replacement. Very common issue. The AV48WP74 -AV65WP74 convergence repair kit from www.tvrepairworld.com has the 2 ICs and associated resistors plus the CD with repair instructions.
Aug 16, 2011 | JVC AV-65WP74 Rear Projection Television
AV-56WP74 the convergence is off. blue is way out!
You will need to replace the Convergence ICs and resistors you can get the JVC repair kit called the AV48WP74-65WP74 convergence repair kit from www.tvrepairworld.com which contains the ICs , resistors and the CD with instructions,
Sep 23, 2010 | JVC AV-56WP74 56" Rear Projection...
Double images with one of the images being red.
very common problem caused by failure of the convergence ICs. You can get the AV48WP74 convergence repair kit from www.tvrepairworld.com which has the ICs, Resistors and also contains the instructions on CD
May 12, 2010 | JVC AV-56WP74 56" Rear Projection...
I'm looking for a replacement convergence board for my Jvc AV48WP74 tv. SSB-5068A-M2 I've replaced the STK392-150 ic's already and after a week they failed again. JVC does not return my calls.
A Google search for the board part number returned several sources. Here's one. You should also check the values of resistors around the STK's. When the IC's fail, the resistors can change value which can cause the repeat failure you're experiencing.
Sep 24, 2009 | JVC AV-48WP74 48" Rear Projection...
Jvc av48wp74 horizontal convergence unadjustable after after repair
you have to lift one side of the resistor from circuit in order to measure resistance otherwise a open resistor will not read open as you will be reading the resistance from the surrounding circuit. Always lift one side of a resistor out of circuit when testing with a ohms meter.
Jun 06, 2008 | JVC AV-48WP74 48" Rear Projection...
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
ConvergenCE problem still after replace the chips
Check the resistors on the convergence board by the IC's. Chances are that 1 or two of them are open. If you can't fix it, you can remove the convergence board and send to PTS electronics and have it rebuilt.
Dec 14, 2007 | Mitsubishi WS-55807 TV
have pts rebuild the board which will cost around $130, www.ptscorp.com, or replace the stk392-110 x 2 located on the convergence panel.
Dec 08, 2007 | JVC AV-48WP74 48" Rear Projection...
PCB's when available,are expensive.Replace convergence IC(s),
re-adjust and you are good to go!
Oct 12, 2007 | JVC AV-65WP74 Rear Projection Television
Convergence problem for my JVC Av48wp74
replace the convergence amp IC that is the defective parts!
Oct 02, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
