Question about HP Compaq nc6220 Notebook
Ps/2compatible mouse for hp laptop can not respond to touches
  • 101 Answers
Ps2 mouses dont work so goog with notebooks,try using a usb mouse
Posted on Jul 03, 2009
My mouse pad in my computer wont work when i tap it
It will depend on what touch pad (and related software) is installed on the particular computer, but you will find the tap option under the Control Panel. Open your control panel, select "Mouse" There will be a TAB in the mouse properties called "touchpad" (surprise, surprise!) where you can toggle tapping on/off.
Hope this helps. PS: if you DONT see the touchpad option - you will first need to install the drivers/software for your touchpad. Most HP touchpads are the Synaptics Touch Pads - Find the drivers here: --> Click here!
Feb 07, 2011 | HP Computers & Internet
Cusor goes crazy and goes an does whatever it wants won;t respond to any touch pad movements
If an external mouse does not fix the problem, then it may be an internal O/S or connection fault.
Apr 09, 2010 | HP Pavilion dv9000z Notebook
I was sold a mouse...with a round end....where is the portal on the computer?
That end is a PS/2 connector most modern day laptops do NOT have this connector, you need a USB Mouse, I suggest you take it back and try and swap it, for one compatible with your PC.
Feb 22, 2010 | HP Presario C555nr Notebook
TOUCH PAD DOES NOT RESPOND ON MY PAVILION DV7 1130US LOOSE CABLE POSSIBLY?
I don't think the cable is loose but the cable could go bad. touch pad circuit board could be bad or the mother board. You have to treat it like a science project and these are the steps i would go if you want it back to normal. Replace the hole palm rest area if that doesnt fix it then the mother board. you could get a usb mouse also look in the control panel and look for the mouse and there is a troubleshoot area.
Jan 26, 2010 | HP Pavilion dv7-1130us laptop
Our touchpad is not responding to tapping. It
Go into the BIOS (F2). Press Alt-P until you reach "Page 4 of 7". Under "Pointing Device" change the setting from "PS/2-Touchpad" to "PS/2". Reboot.
The touchpad and point stick will still function as long as there isn't a mouse plugged into the PS/2 port. If the mouse is plugged in, it will override the integrated devices.
Sep 23, 2009 | Dell Latitude C640 Notebook
Its starts in safe mode,and the touch pad wont respond
the touch pad could have simply failed, most OS will interpret the mouse pad as a mouse to make it work, so if its gone its most likely not working, I mouse attached to a usb or one of the ps 2 connections might give you a mouse back temp you can replace most mouse pads.
hope this helps
Apr 07, 2009 | Acer Extensa 5420-5687 Notebook
Have a problem with my mouse pad on my laptop
GO into your mouse properties in the control panel and make sure you have the touchpad mouse turned on. This is a link that should give you any drivers you need.
http://www.microsoft.com/hardware/download/download.aspx?category=MK
Hope this solves your problem
Dec 23, 2008 | Sony VAIO VGN-FE590 (VGNFE590P03) PC...
Sensitive mouse pad
If I'm wrong they have a button to close it down.Have a look it should be next to the synaptic mouse.
takecare.
Apr 27, 2008 | HP Pavilion dv4000 Notebook
Alps pointing device software
down load synaptics touchpad driver first.
once downloaded open the file to install.
before u install go into device manager..check mice and pointing devices and look for ps/2 compatable mouse....delete it and restart pc on restart it will find and reinstall ps/2 mouse.
if everything works,sorted ,if not install touchpad driver downloaded earlier.
you can find this driver on hp site.this driver works on all hp laptops.
Apr 07, 2008 | Compaq Evo N610C Notebook
HP Compaq nc6220 Notebook Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
