Question about Saeco Starbucks Sirena Espresso Machine
Water sprays out between portafilter and brewhead.
Water sprays out on the side between portafilter and brewhead. Does this even when testing with no coffee in the portafilter. Sometimes makes a popping noise.
I had the same problem when I started using the Sirena. When I put the portafilter on I was lining it up with the arrow. I found that if I tighten the portafilter on all the way to the right (past the arrow) it works perfect, no water spraying.
Posted on Jul 12, 2009
    President:
  • 1,952 Answers
Make sure the water reservoir is full and properly fitted into its position.
Posted on Jul 03, 2009
Why is there water spraying from coffee head and surrounding area
Grind is too fine and the portafilter chokes when water hits the coffee; or the seal in the brewing head is shot.
Jul 31, 2014 | Gaggia Baby Coffee Makers & Espresso...
How do i fix the Coffee flow from only dripping through?
if it has a filter ,replace. use vinegar through the water resevoir. fill it and turn it on.
May 26, 2014 | Rancilio Silvia Espresso Machine
My EM100 Espresso Maker will not brew? Water comes out when no portafilter on, but not when filter on for brewing? Help!!
This is a complex problem. 1. remove, check and clean brewhead (round screen above portafilter where water comes out); it can become clogged with gunk. 2. brewhead gasket may be old or damaged, they can be purchased on eBay. 3. brewing basket may have become clogged, I don't know if running cleaner solution through it will help, may have to replace it. 4. Likeliest source of problem is coffee ground too fine and/or tamped down too hard. These are not professional level machines and cannot work with very fine grind or heavy tamping. Try a coarser grind and a light tamp with the larger brew basket. Coffee must be ground with good quality burr grinder for correct consistency. John Saxon/
See my espresso-making blog at motophoto.posterous.com
Dec 15, 2011 | Cuisinart EM100 Stainless Steel Espresso...
Coffee sprays from portafilter spouts while pulling shot
Either the group gasket is dirty or damaged. Also check the basket for damage.
Jul 21, 2010 | Gaggia Classic Espresso Machine
The water temperature is only at 160 F. from the portafilter. What to do about this if 190 F is optimal?
Make sure portafilter is warmed up before checking or check without portafilter, descale boiler, and check to make sure thermostat and element is working properly, do a resistance test.
Jan 24, 2010 | Gaggia Classic Espresso Machine
The pump does not run water through the filter head. It makes a noise and pumps the hot water back into the water tank
Almost certainly due to the reverse side of the brewhead being scaled up. The evolution has a recess on the reverse of the head that block causing no water to come out. Remove the head and clean it off.
Dec 31, 2009 | Gaggia Evolution Espresso Machine
No water coming through portafilter to make espresso.
You have a stuck check valve. Try running the pump with the steam knob open, then shutting it then, opening it 4 or 5 times and see if it will pop open. Make sure that you don't have the portafilter in at the time you are doing this.
Dec 03, 2009 | Saeco VIA Venezia
I don't have enough water pressure to make cofee. Very little water comes out of the shower head. The shower head is clean, it is not plugged. I suspect it is the pump? Please advise
I had the same problem: clean showerhead, machine pumps hot water just fine, but very little brewhead flow. Descale made it worse but that was a big clue! I took apart the brewhead and found grains of scale in the boiler, like pulverized beach shell:
Some of those bits apparently made their way into the three way valve and clogged it. I could not blow air through the channel between the plunger and the boiler. Not surprising: the inlet hole inside the valve is TINY and clogs easily.a0bc8304-2405-4fdb-a444-21cf80e7701a.jpg
Once I got this part cleared up inside (and cleaned out the rest of the scale from my boiler so it didn't immediately re-clog!), my brew flow was restored.
Sep 05, 2009 | Gaggia Classic Espresso Machine
Half of the time, espresso leaks (or sprays) out of multiple points on the handle/portafilter, instead of coming out of the two designated holes. Almost as if too much pressure builds so it gets forced out...
Try running water only and see if you get the same result. If you do, then soak the filters and the bottom of the metal basket of the portafilter holder in vinegar (distilled white). In my experience, this unit requires constant cleaning. But the espresso is good.
-Tha Mp3 Doctor
Jan 12, 2009 | Cuisinart EM-200 Espresso Machine
Saeco Starbucks Sirena Espresso Machine Logo
534 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
