Question about Goodman GMS90703BXA Heater
Pilot on but no heat to radiators
Our heat is not on , the pilot is lit but no heat is in the radiators. we don't know alot about plumbing or heating and we have a newborn in the house, so we need to do something. don't have much money either. any help would be greatly appreciated in terms women can understand(those of us not educated in this area)
  • el wapo Feb 19, 2008
    three rads upstairs at back of house not heating all other rads in house working normally.House is oil heated
  • 42 Answers
There is a gas valve inside the heater (is it on?), There is also sometimes an electric starter that goes bright on start (is it?), Do you hear whirring noises on start? Is the valve switch set to ON?
I have one of these and if the pilot (electrical) turns on and the gas is not flowing then is senses a heat failure and stops. Then on the control board light blinks (seen through plastic cover).
These also have to spin an exhaust fan, that bearing sticks, if it fails to turn, the unit will fail to start after 1 min. Does any of that makes sense?
Posted on Nov 10, 2007
In my gas heater, my pilot light is lit but there is no heat coming out.
Did you turn the control knob to heat from pilot setting? don-ohio
Jan 26, 2017 | Heating & Cooling
When you turn the gas control knob from pilot to on it keeps going out takes 3 or 4 times to stay lit when u turn it on
Are you letting the pilot flame heat up the thermocouple for one minute before you try to turn to ON? don-ohio
Jan 13, 2017 | Heating & Cooling
My pool heater doesn't come on. The pilot is lit, and the valve to the ON position. I turn the front knub to heat but when I turn the switch on the front panel to ON it doesn't fire on (...
If your pilot light is lit, then you do have some gas flow, so it is probably the thermocoupler (the part heated by the pilot light) that is not telling the gas valve to open the main line. Sometimes it is just a case of residue on the thermocoupler that is not letting it get up to temperature and sometimes it has been knocked out of alignment and the pilot light is not putting direct heat on it.
A cleaning with steel wool (don't overdo it) would take care of the residue, and you can GENTLY move the thermocoupler back over the pilot flame. If neither of that helps then replace the thermocoupler.
Jul 01, 2011 | Hayward 250 1 Millivolt Propane Pool...
No Hot Water
Well, let's start the trouble shooting process with trying to get the pilot lit...
Have you removed the cover at the bottom of the heater?-- Can you see an pilot light inside?
If not, Can you try lighting the pilot-- and noticing how the pilot flam heats the little ThermoCouple (TC)?
Note: In order for gas to flow thru the main control valve, the pilot light has to be heating the TC-- to generate a voltage, that in turn allows the main gas valve to open.
Do you need help in getting the pilot light lit?-- do you understand the need to hold down the start button, until the TC gets heated up?
Let us know what you find
Mack B
Jan 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have switched my unit over to heat and only cool air blows out. Is there a reset button I can try before calling out a repair man.
It depends on what type of unit you have if it is gas or electric. If it is gas your pilot light is probably not lit .take the top door of your furnace off look under the burner and see if there is a small flame lit . if not it is simple to light turn the knob on the gas valve to pilot then push in on the know while holding a match at the pilot head to find the pilot head trace the small aluminuim pipe from the gas valve to where it ends that will be the pilot head once the pilot lights count to 10 slowly then switch the knob to the on position and your set make sure the t-stat is in the off position before lighting the pilot light.
If it is electric heat strips or a heat pump there is nothing to do other than turn t-stat to heat and make sure all 220 breakers are in the on position.
Nov 16, 2010 | Weather King Heating & Cooling
Worcester heatslave 9.24 pilot light wont stay lit, pressure is o.k. what is the part and where do I get it (thermal coupling?)
thermocouple any plumbing or heating shop juast ask for a universal thermocouple ie honeywell the heating shop willl know what you will need
Apr 13, 2010 | Heating & Cooling
Problem with hot water from Vokera Excell 80sp boiler
Hi - hope someone can help. I have a VOKERA EXCEL 80SP combi boiler and been without hot water/central heating for two days. The pilot light is on, the fan is on, but boiler not triggering once the hot water tap is turned on.
Hopefully someone come to look at it today but hoping for some advice. Anyone else had this problem?
Thank you.
Dec 21, 2009 | Water Heaters
My honeywell gas suspended garage heater will not come on when the t'stat calls for heat. It is a heat only unit and neither the fan nor the blower motor will come on. The Heater is getting power to it...
The pilot light has to be lit before gas valve will operate. That's a safety feature so the valve won't open and fill the garage with gas and possibly cause an explosion or fire. If you have a standing pilot and can't get pilot to stay lit, it's usually the thermocouple and it will need to be replaced. Once the pilot is lit, the gas valve comes on and heats the combustion chamber up to approx. 100° to 125° a thermostat controlled fan switch will close and bring the blower on.
Sep 08, 2009 | Mr. Heater Suspended Garage Heater
My pilot light will light, but will not stay lit? I have a gas whirpool water heater aprox 1 1/2 years old.Thisis the first time we have encountered any problems with our appliance.
Once the flame has struck it heats up a thermocouple that in turn holds the gas valve open
It is a safety measure in case the flame blows out and the gas keeps on coming.
Sometimes the end of the thermocouple gets dirty and a scrub with a fine emery board does the trick
If not it is a new part (They are not that expensive)
Jul 07, 2009 | Whirlpool Water Heaters
Goodman GMS90703BXA Heater Logo
70 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
