Question about Sta Rite STA-RITE IGNITION CONTROL MODULE - 42001-0052S
Pool heater my sta rite pool heater ignition control goes into lockout mode. can you give me some causes for this
  • 83 Answers
If the heater fails to ignite after three attempts, the heater will automatically go into Lock Out. This is a safety feature on the heater.
Things for you to look at to see what is causing the problem are the display panel and diagnostic lights. When you turn on the heater, is it reading the correct water temp? If not, the Thermister has gone bad and will need to be replaced. When you try to start the heater, is there an Error Code displayed? Which of the Service Lights are coming on when the heater will not light? If it is the Serivce System, that is usually low flow of water. You may have a dirty filter, skimmer or pump basket full of debris, or a valve not completely open.
If the Service System light is the one coming on, then you will need to take off the top two halves of the heater and turn over the Display Panel. There are diagnostic lights on the back side of the panel. There may be a red light next to any of the following:
AGS, AFS, SFS, HLS, PS or THERMISTOR
If there is a red light next to one of these, then that is what has malfunctioned. If you need an Owner's Manual for the heater, you can find one online at the following link:
http://www.inyopools.com/owners_manual/sta-rite_heaters_max-e-therm.pdf
Posted on Jul 08, 2009
Diagnose Ignition Control Module
means unit tried to fire 3 times then locked out turn off then turn back on check ignitor
Feb 07, 2018 | Sta Rite STA-RITE IGNITION CONTROL MODULE...
Soft lockout pool heater
check gas and ignitor
Aug 13, 2012 | Sta Rite Pool & Spa
What causes ignition lockout
high limit switch open, look for a reset button between the two leads going to it. Check the wiring diagram for placement of the switch. You could also have a bad pressure switch, jump it to test.
Mar 11, 2012 | Sta Rite Sr333lp - Max E Therm - Pool &...
High limit switch is bad or open or pressure switch is bad.
Mar 11, 2012 | Sta Rite 333 Btu Natural Gas Heater...
Igniter lockout based on led flashing 3 times. I replaced the igniter so I know it is new. The blower spins up and I see my natural gas meter spinning providing gas. Not sure what else to check at this...
This issuesounds tricky. I recommend you call the Sta Rite technical support at888-782-7483 and they should be able to help you figure this issue out.
I hopethis helps.
Oct 08, 2011 | Sta Rite Sr400na Max E Therm Pool & Spa...
The heater ignites, stays on about 20 seconds and goes off, after starting and stopping 3 times, it displays a service heater light.
It may not be detecting that ignition occurred. There is usually a sensor that detects ignition and if it is not working right the controller tells yo to service the heater. If you call Sta Rite technical support number they may be able to help you determine what device needs to be replaced. I hope this helps.
Aug 13, 2011 | Sta Rite 460763 Max-E-Therm Pool and Spa...
Sta rite heater won't start
TURN THE BREAKERS OFF FO R 20 SEC IF PROBLEMS PERSIST SEE CODE A POST
Dec 06, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Sta Rite STA-RITE IGNITION CONTROL MODULE - 42001-0052S Logo
780 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
