Question about Siemens Cell Phones
Hi I have an old siemans S55 car kit installed in my car - which I now do not use. I have a Garmin GPS 670 and would like to conect the voice system to my car audio (FM transmitter no good as too many siadeband interference). What two leads do I need to connect to in the car kit that would amplify the garman throught the system? Thanks for your help (ashjem@lineone.net) 0208 144 6711 Kevin
  • 6 Answers
SOURCE: BLUETOOTH Car Kit Type No. BTHCK 100
Connect the fuse kit's GREEN Ignition Sense wire (3 amp fuse - switched) to an ignition switched location on the fuse block. When the ignition is off the sense line is low.
Connect the ORANGE entertainment mute wire to the vehicle's entertainment system. (that is if your stereo supports it)
Connect the RED Positive primary lead to a 4-10 amp fused connection
Connect the BLACK ground wire to the vehicle chassis.
YELLOW & BLUE are not used.
Posted on Aug 24, 2008
SOURCE: Garmin 760 - No Voice Directions
Check The system settings, I had to download the newest version of the audio software for the voice to work. The software vanished once and I had to re-download it using the web updater.
Hopefully it will stick around this time.
When I load the new software the voice works.
Posted on Oct 20, 2008
SOURCE: STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Posted on Dec 11, 2008
Go back into your tools and settings and re select the voice of american jack and see if it comes back on.
I lost the voice 2 days ago while on a trip from tenn. to florida and this fixed it. we never shut off the voice but somehow while using bluetooth or FM trans it shut off voice transmiting.
Posted on Dec 17, 2008
  • 4 Answers
SOURCE: no sound from Garmin nuvi 760 by any method
Sounds like your speaker went south. Since your fm transmitter is working I'll be your earphone jack is too. So you could always use an earphone. Only other option is a speaker replacement.
Posted on Jan 07, 2009
Why wont my computer recong my garmin
To let a computer work with a Garmen, you need to install software that came with your GPS. On the disk are also all drivers for all known operating systems.
First install the software, than connect.
Feb 28, 2014 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
My garmin nuvi 670 has stopped talking to me ... no volume ? Any ideas
I assume you've checked that it's not muted or that the volume is not fully down.
  • Press TOOLS at the bottom right corner of the screen that says WHERE TO and VIEW MAP
  • Press SETTINGS
  • Press LANGUAGE
This brings you to a screen with 3 items. VOICE, TEXT LANGUAGE and KEYBOARD
  • Press VOICE and select an English speaking voice. This may solve the problem. If it doesn't it may be because the voice file is corrupted and needs to be downloaded again.
To download it again,
  • Download and install WEBUPDATER from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
  • Connect your satnav to your computer and run webupdater
  • It will search for updates to your software and if it finds some it will install them. When the installation is complete it will give you the option to download some extras including voice files.
  • Select the voices you want by ticking them and click next to download them to your satnav.
  • When they are downloaded you'll need to select the one you want by going back to the LANGUAGE icon and pressing VOICE as described in the first paragraph above.
Feb 11, 2011 | Garmin nuvi 670 GPS Receiver
I have Garmin 670. The bluetooth worked fine until yesterday. I have no sound.
Check your Volume mute if ithas a checkmark in it remove it.....
Check the FM Transmitter if it is Enable with a checkmark remove it.
Check the Language make sure you have one that has ( TTS ) chosen those are the only ones with voice
Hope this helps
Oct 25, 2010 | Garmin nuvi 670 GPS Receiver
Voice navigation is distorted
With unit plug in to computer using the USB connector
Go to www.garmin.com and do a firmware update.
Install replacement battery in Garmin Nüvi 660 and 670. How is cabinet opened?
The Garmin 660 and 670 like most Garmin satnavs cannnot be opened unfortunately. Garmin say that the battery may be replaced by sending the unit back to them only.
Jul 24, 2010 | Garmin Nuvi 660 GPS Receiver
My gps is not telling street name were i have to turn
Tap "Tools", "Setting", "Language", under "Text", choose "American English", under "Voice", choose a voice that speaks street names.
Please let me know if it helps.
Thanks
May 02, 2010 | Garmin nuvi 205W GPS Receiver
The 670 garmin shut down then say's low battery
musicman340,
It sounds like the rechargeable battery inside your gps is coming to the end of its life. After enduring the temperature extremes of your car in addition to numerous charges and discharges, these batteries do eventually die after a couple years. How old is your nuvi? If this is the problem, the good news is that you don't have to throw your gps away as this battery is readily replaceable if you follow the steps in this video:
The company that produced the video sells a kit which includes the battery and tools necessary to replace your battery. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+670&Show=ExtInfo
I swapped the battery of a friend's dying GPS using the aforementioned kit and all went well. His nuvi is back up and running smoothly.
Mar 15, 2010 | Garmin Nuvi 760 Car GPS Receiver
Touch screen not working on garmin nuvi 670
Has this been solved? Hold power switch to right for about 30 seconds then follow on screen help to recalibrate screens
Dec 11, 2008 | Garmin 010-00358-00 GPS Receiver
Cell Phones Logo
53 people viewed this question
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Yoav Shilon
Yoav Shilon
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
