Question about Acer Computers & Internet
Acer Aspirre 5735 no longer detects wireless networks. Got my laptop back from warranty claim (new motherboard).. 2 days later wireless stoped working. Whn I press the wireless button, screen messae says enabled, but light does not come on. If I click button again screen message says it has been disabled. Checking under windows, control panel says the wireless is working ok, however under wireless connections, whn i diagnose problem it says wireless is turned off and I should turn it on.
Hi, my acer 5735 shows 5 flashings in the battery led when i press the power button. What does this means?
I had this problem with my acer before its the motherboard if its in warranty you should send it back to acer and they'll fix it for free and if its a manufacturer like mine was even if its not under warranty they have to fix it for free. http://www.acer.com/worldwide/selection.html
May 20, 2011 | Acer Aspire 5735 Notebook
My computer left mouse button will not work.
Claim warranty support if you can, alternatively take it in to a computer technician for repairs.
damnor01
Feb 01, 2011 | Acer Aspire 5735 Notebook
Laptop will only charge when switched off
get orignal charger for acer aspire 5735 pc and then try again
May 03, 2010 | Acer Aspire 5735 Notebook
My acer 5735z has stopped connecting to the wireless internet, it does work when I have the cable in
Go to SafeMode with Networking and check if the wireless is detecting any networks, if yes, issue is with the Security Software or else, reinstall the Wireless Network adpater driver from Acer recvoery manager.
Mar 10, 2010 | Acer Aspire 5735 Notebook
Network and wireless was not detected
Hi i understand the importance of your problem
there could be 2 reasons for your issue
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2. Find and double-click “Network Connections” to open up the list of connections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
Jan 01, 2010 | HP Compaq Presario F500 F700 and G6000...
Acer extensa 4620 Since purchased, wirelss
Try turning off your Acer wireless control and use "Wireless Zero Configuration"
Nov 27, 2009 | Acer Extensa 4620 Notebook
I have an Acer Aspire 5735 RAM
If computer is booting, connect the laptop to an external display , and start it up. If you have display in there , then the problem is a faulty inverter.
If you have no display, then the most common fault is the motherboard.
If computer does not start at all, then it is probably the DC connector on laptop motherboard. It must be re-soldered.
A motherboard fault is not that bad. Motherboards are replaced by Acer at a not too high price, or under warranty. Replacing motherboard you will not lose any of your data and the computer will restart in the same condition it was before the fault after replacing motherboard.
I am an authorized Acer representative and technician. They have an excellent customer service (at least here in UK). They will send a courier to collect and deliver back the computer, they have low prices on repairs, and warranty extension options. Call Acer and discuss the repair.
If Acer does not have the motherboard , then repair may get expensive. Third party price will start from about $220 for used or refurbished part.
Sep 26, 2009 | Acer Aspire 5735 Notebook
NETWORK IS NOT CONNECING IN wi-fi in our wireless network with WPA2 system. but its detecting the network. should i install any new software to support WPA2.
try to setup again  wireless card's driver  if it doesnt work your wireless car is break down.
have a nice day and sorry for english.
May 27, 2009 | Acer Aspire 3680 Laptop
Wireless on/off button doesn't detect wireless card.
drivers possibly or if its a switch then a bad switch
Apr 30, 2009 | Acer Aspire 6920 Notebook PC
Computers & Internet Logo
196 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
